Add mesh, align to view, un check align to view. not updating. #28805
Reference: blender/blender#28805
%%%1. add mesh
2. check align to view (mesh aligns to view)
3. uncheck align to view (mesh doesn't refresh, neither does X;Y;Z rotation inputs)
revision 40789
mac osx 10.7 lion
%%%this is surprisingly not easy to solve since there are 2 settings which modify the object rotation and one overrides the other.
problem is that setting view align sets rotation so when its clicked off it just uses the rotation set by the view.
Not that fussy on how this is done but can see its a bit stupid.
I'm tempted to have an align to view operator and remove it from the add-object operators.
This way the user preference is used by the operator, and if the user wants to align to the view in any other context its an explicit action.
Another way to solve is to have the view align not initialize the operators rotation, so the object will be rotated to the view but rotation will read 0,0,0. this is confusing in a different way but at least clicking off 'View Align' will reset the object.%%%
%%%and I just thought a update() function was left out ^^
because if you hover the inputs you see the X;Y;Z shows the view rotation as you said.
last mentioned solution, wouldn't that be confusing? the added mesh has a obvious rotation, but XYZ says all 0,0,0?
could a temporary 3d vector variable be created at operator call? this 3d vector has 0,0,0 rotation.
and if the align-to-view is un checked the mesh wil be rotated according to this temporary 3d vector ?
so rotation is never set, it's always read either from 3d viewport rotation, or this temporary 3d vector.%%%
%%%and if user is inputing XYZ rotation, he's actually rotating this 3d vector, and mesh is reading it's XYZ rotation.%%%
%%%I think align to view should be part of the operator, there's many operators that work this way, getting their default parameters from the user preferences. I think the problem is in ignoring align to view when the rotation is set. To make that more clear, the rotation values could be grayed out in the UI when align to view is enabled.%%%
%%%@brecht, the problem with always using the view align option is the object will always snap to the view rotation, even when changing other settings, maybe this is OK though it used to do this and IMHO was odd/annoying.
Since you add the object (View align on in userprefs), rotate the view, change the location --- object faces view again.
%%%Prepared patch for this issue: http://www.pasteall.org/25391/diff
IMO, storing rotation to prevent re-aligning when adjusting other settings reduces amount of confusing thing. So it was only issue of re-setting stored rotation when toggling Align To View option.
Prefer Campbell/Brecht to verify way of resetting rotation before commit.%%%
%%%Campbell, indeed, I didn't consider that.
Sergey, this looks like a good fix to me.%%%
%%%Patch commited to svn rev40831.
Thanks for the report, closing.%%%
