"Follow path" constraint subframes calculated incorrectly #29113
Reference: blender/blender#29113
%%%Subframes calculated for "Follow Path" constraint's "Offset" property are calculated incorrectly, making object appear ahead it's real position. Same thing probably happens with other Blender components as well, but at least with this one. :)
How to reproduce:
However, if you render whole frames or preview it through the timeline, it's shown correctly.
That scene is rendered with full sample motion blur of 6 samples and shutter time of 3 frames. So from the code point of view, the last "blur sample" is rendered at full frame (scene->r.cfra) of 1, and subframe (scene->r.subframe) of 3.0.
(This isn't isn't a bug in full sample motion blur calculation but in animation system. I originally run into this while testing Dynamic Paint subframes. :)%%%
%%%Joshua: old style motion blur is using subframe steps. Can you check if the new animation system correctly uses it?
Thanks!%%%
%%%For starters, this file is going about things in the wrong way.
The "offset" value you've animated here actually acts like a user-controlled "time lag" on top of the curve evaluation time (+ subframe offset) if "fixed position" is disabled. %%%
%%%EDIT:
However, checking more carefully (i.e. even in case with animating "evaltime" directly), it seems that the problem here was actually applying the subframe offsets, instead of forgetting to apply them. This is because by the time the constraint gets the time, it has already had time offsets applied, but applying manually just compounded the problem!
So, fixed in svn!
