Snapping control points are not taken into account during Scaling/Rotating #29153
6 Participants
Reference: blender/blender#29153
%%%When "Snap during transform" is on, while performing the translation, the control poins (added with hotkey A) are taken into account. However, when rotating or scaling its effect is null. This applies only to vertex, edge, face and volume snapping.
However, I'm not sure if this is a bug, or a logic consequence of the type of operation. But then, I think control points shouldn't be allowed?
Regards.
Pep.
%%%Hi! I tried to test this but it seams to work ok even when using rotation/scaling. Rotation snap is 5 degrees.%%%
%%%You mean snapping at increments. What I meant was snapping in any other mode, and using the control points added with hotkey A, during transform.%%%
%%%ubuntu 11.04 rev41611
It works, here.%%%
%%%Well, it seems to work in edit mode/object mode for most of cases.
Only one problem, here. Scaling in object mode with A control points scales object to inf values. %%%
%%%It works ok when you place a single snap point. However, the effect in grab mode is that it snaps to the median point of those snap points, and you can "weight" them by duplicating snap points in a particular vertex for instance. In scale/rotate mode it looks like this behaviour is not applied. It looks like it snaps to the LAST snapping point you insert.
%%%Will add to the transform todo list, we need a new developer to adopt the code.%%%
This issue was referenced by
8573c1a847
Changed status from 'Archived' to: 'Resolved'
