Crash - Complex case #29530
Reference: blender/blender#29530
%%%winXP, 32bit, r42469
click on "Bake All Dynamics"
click on "Object Mode" then select "Particle Mode"
and it crashes.
I think it's somehow linked with that Keyed Particles can't be cached (maybe) and that
in Keyed Particles sequence I used one PS with Newtonian physics.
Sorry, maybe the file isn't very simple but I had no time to setup this thing again.
%%%Crash confirmed, assigned to Janne.%%%
%%%Confirmed - FreeBSD 8.2 x86 r42565
I also found a bit more - with a saved startup blend (from a while back) I can start and add particles to the default cube, play a few frames, pause, bake all dynamics, change to particle mode and crash.
If I delete the startup blend so that it uses the internal default blend I can follow the same steps but instead of crashing, particle mode shows up with hair. Object/weight/etc modes still shows small particles but particle mode shows hair.%%%
%%%Shane, I guess that these hair are editable (after Baking) and allow you to tweek particles' flow. Actually that was why I found this bug - I wanted to edit my particles' flow.%%%
%%%The case I mention it shows hair strands in particle mode instead of crashing. If I don't play the animation before baking and going to particle mode it shows particles as expected. I mentioned it as it may be a clue as to what causes the crash.%%%
%%%Thanks for the report and sorry for the delay! Fix committed in r44045.%%%
