curve properties, geometry lacking units #29547
2 Participants
Reference: blender/blender#29547
%%%simple enough, just not sure if this is okay in bcon4.
Index: source/blender/makesrna/intern/rna_curve.c
+++ source/blender/makesrna/intern/rna_curve.c (working copy)
@@ -1286,21 +1286,21 @@
RNA_def_property_ui_text(prop, "Bevel Resolution", "Bevel resolution when depth is non-zero and no specific bevel object has been defined");
RNA_def_property_update(prop, 0, "rna_Curve_update_data");
RNA_def_property_float_sdna(prop, NULL, "width");
RNA_def_property_ui_range(prop, -1.0, 1.0, 0.1, 3);
RNA_def_property_float_funcs(prop, "rna_Curve_offset_get", "rna_Curve_offset_set", NULL);
RNA_def_property_ui_text(prop, "Offset", "Offset the curve to adjust the width of a text");
RNA_def_property_float_sdna(prop, NULL, "ext1");
RNA_def_property_ui_range(prop, 0, 100.0, 0.1, 3);
RNA_def_property_range(prop, 0.0, FLT_MAX);
RNA_def_property_ui_text(prop, "Extrude", "Amount of curve extrusion when not using a bevel object");
RNA_def_property_float_sdna(prop, NULL, "ext2");
RNA_def_property_ui_text(prop, "Bevel Depth", "Bevel depth when not using a bevel object");
%%%Patch committed, thanks.%%%
