keyboard event missed when toggle too fast #29586
Closed
opened 2011-12-11 21:53:24 +01:00 by francoisgfx · 6 comments
%%%while matchmoving I noticed blender was missing/skipping some keyboard event when doing it to fast.
using the left and right arrow key very past to compare two frames in MCE, I noticed sometimes blender would skip an event since it would go more than one frame. For instance:
  • click left (goes previous),
  • click right (goes next but skip/missed this one)
  • click left (goes previous again)
so I would guess is is related to keyboard event. %%%
%%%while matchmoving I noticed blender was missing/skipping some keyboard event when doing it to fast. using the left and right arrow key very past to compare two frames in MCE, I noticed sometimes blender would skip an event since it would go more than one frame. For instance: - click left (goes previous), - click right (goes next but skip/missed this one) - click left (goes previous again) so I would guess is is related to keyboard event. %%%
Author
Author
%%%oops forgot to specify :
Blender 2.60 (sub 7) System Information
Blender:
version 2.60 (sub 7), revision 42542. Release
build date: 2011-12-09, 23:18:03
platform: Darwin:64bit
binary path: /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/blender
build cflags: -DWITH_QUICKTIME -isysroot /Developer/SDKs/MacOSX10.6.sdk -mmacosx-version-min=10.6 -arch i386 -pipe -funsigned-char -DNDEBUG -O2 -ftree-vectorize -msse -msse2 -msse3 -mfpmath=sse -m32 -DGHOST_COCOA -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE
build cxxflags: -isysroot /Developer/SDKs/MacOSX10.6.sdk -mmacosx-version-min=10.6 -arch i386 -pipe -funsigned-char -isysroot /Developer/SDKs/MacOSX10.6.sdk -mmacosx-version-min=10.6 -arch i386 -DNDEBUG -O2 -ftree-vectorize -msse -msse2 -msse3 -mfpmath=sse -m32 -DGHOST_COCOA -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE
build linkflags: -mmacosx-version-min=10.6 -Wl -isysroot /Developer/SDKs/MacOSX10.6.sdk -arch i386 -fexceptions -framework CoreServices -framework Foundation -framework IOKit -framework AppKit -framework Cocoa -framework Carbon -framework AudioUnit -framework AudioToolbox -framework CoreAudio -framework OpenAL -m32 -framework QuickTime
build system: SCons
Python:
version: 3.2.1 (default, Aug 5 2011, 20:41:36)
[GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
paths:
/Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts/addons_contrib
/Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts/startup
/Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts/modules
/Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/python/lib/python32.zip
/Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/python/lib/python3.2/
/Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/python/lib/python3.2/plat-darwin
/Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/python/lib/python3.2/lib-dynload
/Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts/addons/modules
Directories:
scripts: ['/Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts']
user scripts: None
datafiles: /Users/francoistarlier/Library/Application Support/Blender/2.60/datafiles/
config: /Users/francoistarlier/Library/Application Support/Blender/2.60/config/
scripts : /Users/francoistarlier/Library/Application Support/Blender/2.60/scripts/
autosave: /Users/francoistarlier/Library/Application Support/Blender/2.60/autosave/
tempdir: /var/folders/j2/j2CXhyN9FxKQVrxbpJ+tiU+++TI/-Tmp-/
renderer: ATI Radeon HD 6490M OpenGL Engine
vendor: ATI Technologies Inc.
version: 2.1 ATI-1.6.38
extensions:
GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend
GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader
GL_ARB_shading_language_100 GL_EXT_multi_draw_arrays
GL_EXT_clip_volume_hint GL_EXT_rescale_normal
GL_EXT_draw_range_elements GL_EXT_fog_coord
GL_EXT_gpu_program_parameters GL_EXT_geometry_shader4
GL_EXT_transform_feedback GL_APPLE_client_storage
GL_APPLE_specular_vector GL_APPLE_transform_hint
GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object
GL_APPLE_vertex_program_evaluators GL_APPLE_element_array
GL_APPLE_flush_render GL_APPLE_aux_depth_stencil
GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip
GL_SGIS_generate_mipmap GL_ARB_imaging GL_ARB_point_parameters
GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp
GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map
GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine
GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat
GL_ARB_shadow GL_ARB_depth_texture GL_ARB_shadow_ambient
GL_ARB_fragment_program GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite
GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object
GL_ARB_pixel_buffer_object GL_ARB_draw_buffers
GL_ARB_shader_texture_lod GL_ARB_color_buffer_float
GL_ARB_half_float_vertex GL_ARB_texture_rg
GL_ARB_texture_compression_rgtc GL_ARB_framebuffer_object
GL_EXT_compiled_vertex_array GL_EXT_draw_buffers2
GL_EXT_framebuffer_object GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample GL_EXT_texture_rectangle
GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color
GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias
GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap
GL_EXT_texture_filter_anisotropic GL_EXT_separate_specular_color
GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs
GL_EXT_stencil_two_side GL_EXT_texture_compression_s3tc
GL_EXT_texture_compression_dxt1 GL_EXT_texture_sRGB
GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp
GL_EXT_packed_depth_stencil GL_EXT_bindable_uniform
GL_EXT_texture_integer GL_EXT_gpu_shader4 GL_EXT_framebuffer_sRGB
GL_EXT_provoking_vertex GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422
GL_APPLE_rgb_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range
GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float
GL_ARB_half_float_pixel GL_APPLE_pixel_buffer
GL_APPLE_object_purgeable GL_NV_blend_square GL_NV_fog_distance
GL_NV_conditional_render GL_ATI_texture_mirror_once
GL_ATI_blend_equation_separate GL_ATI_blend_weighted_minmax
GL_ATI_texture_env_combine3 GL_ATI_separate_stencil
GL_ATI_texture_compression_3dc GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod GL_SGI_color_matrix GL_EXT_texture_array
GL_EXT_vertex_array_bgra GL_ARB_instanced_arrays
GL_ARB_depth_buffer_float GL_EXT_packed_float
GL_EXT_texture_shared_exponent
%%%oops forgot to specify : **** # Blender 2.60 (sub 7) System Information **** Blender: **** version 2.60 (sub 7), revision 42542. Release build date: 2011-12-09, 23:18:03 platform: Darwin:64bit binary path: /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/blender build cflags: -DWITH_QUICKTIME -isysroot /Developer/SDKs/MacOSX10.6.sdk -mmacosx-version-min=10.6 -arch i386 -pipe -funsigned-char -DNDEBUG -O2 -ftree-vectorize -msse -msse2 -msse3 -mfpmath=sse -m32 -DGHOST_COCOA -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE build cxxflags: -isysroot /Developer/SDKs/MacOSX10.6.sdk -mmacosx-version-min=10.6 -arch i386 -pipe -funsigned-char -isysroot /Developer/SDKs/MacOSX10.6.sdk -mmacosx-version-min=10.6 -arch i386 -DNDEBUG -O2 -ftree-vectorize -msse -msse2 -msse3 -mfpmath=sse -m32 -DGHOST_COCOA -DWITH_MOD_FLUID -DWITH_MOD_OCEANSIM -D__LITTLE_ENDIAN__ -DWITH_AUDASPACE build linkflags: -mmacosx-version-min=10.6 -Wl -isysroot /Developer/SDKs/MacOSX10.6.sdk -arch i386 -fexceptions -framework CoreServices -framework Foundation -framework IOKit -framework AppKit -framework Cocoa -framework Carbon -framework AudioUnit -framework AudioToolbox -framework CoreAudio -framework OpenAL -m32 -framework QuickTime build system: SCons Python: **** version: 3.2.1 (default, Aug 5 2011, 20:41:36) [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)] paths: /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts/addons_contrib /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts/addons /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts/startup /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts/modules /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/python/lib/python32.zip /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/python/lib/python3.2/ /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/python/lib/python3.2/plat-darwin /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/python/lib/python3.2/lib-dynload /Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts/addons/modules Directories: **** scripts: ['/Users/francoistarlier/blender-build/install/trunk/blender.app/Contents/MacOS/2.60/scripts'] user scripts: None datafiles: /Users/francoistarlier/Library/Application Support/Blender/2.60/datafiles/ config: /Users/francoistarlier/Library/Application Support/Blender/2.60/config/ scripts : /Users/francoistarlier/Library/Application Support/Blender/2.60/scripts/ autosave: /Users/francoistarlier/Library/Application Support/Blender/2.60/autosave/ tempdir: /var/folders/j2/j2CXhyN9FxKQVrxbpJ+tiU+++TI/-Tmp-/ OpenGL **** renderer: ATI Radeon HD 6490M OpenGL Engine vendor: ATI Technologies Inc. version: 2.1 ATI-1.6.38 extensions: GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader GL_ARB_shading_language_100 GL_EXT_multi_draw_arrays GL_EXT_clip_volume_hint GL_EXT_rescale_normal GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_geometry_shader4 GL_EXT_transform_feedback GL_APPLE_client_storage GL_APPLE_specular_vector GL_APPLE_transform_hint GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object GL_APPLE_vertex_program_evaluators GL_APPLE_element_array GL_APPLE_flush_render GL_APPLE_aux_depth_stencil GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip GL_SGIS_generate_mipmap GL_ARB_imaging GL_ARB_point_parameters GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat GL_ARB_shadow GL_ARB_depth_texture GL_ARB_shadow_ambient GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_draw_buffers GL_ARB_shader_texture_lod GL_ARB_color_buffer_float GL_ARB_half_float_vertex GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_ARB_framebuffer_object GL_EXT_compiled_vertex_array GL_EXT_draw_buffers2 GL_EXT_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_texture_rectangle GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic GL_EXT_separate_specular_color GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_texture_sRGB GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil GL_EXT_bindable_uniform GL_EXT_texture_integer GL_EXT_gpu_shader4 GL_EXT_framebuffer_sRGB GL_EXT_provoking_vertex GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_rgb_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float GL_ARB_half_float_pixel GL_APPLE_pixel_buffer GL_APPLE_object_purgeable GL_NV_blend_square GL_NV_fog_distance GL_NV_conditional_render GL_ATI_texture_mirror_once GL_ATI_blend_equation_separate GL_ATI_blend_weighted_minmax GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SGI_color_matrix GL_EXT_texture_array GL_EXT_vertex_array_bgra GL_ARB_instanced_arrays GL_ARB_depth_buffer_float GL_EXT_packed_float GL_EXT_texture_shared_exponent %%%
%%%This indeed happens when you're pressing one button before releasing previous. Can remember several reports about this, can't remember if somebody is working on this already or it was moved to todo..%%%
%%%There's this "key modifier" system in Blender, that makes it possible to use any key as a modifier key. If you press right before releasing left, it will interpret this as press right key with left key as modifier, which doesn't match any operator.%%%
%%%Described behavior is helpful in cases like grease pencil drawing. Ideally two non-modifier keys pressed together should be trated as two separated events if there's no operators assigned to event with modifiers. It's not really easy to implement nicely with current event system and we've got some things to be rethinked related on double click and tweak events, so probably better to handle all of them togeter.
Added note in our todo wiki: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/UserInterface#Events
Thanks for the report, closing it now.%%%
%%%Described behavior is helpful in cases like grease pencil drawing. Ideally two non-modifier keys pressed together should be trated as two separated events if there's no operators assigned to event with modifiers. It's not really easy to implement nicely with current event system and we've got some things to be rethinked related on double click and tweak events, so probably better to handle all of them togeter. Added note in our todo wiki: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/UserInterface#Events Thanks for the report, closing it now.%%%
Reference: blender/blender#29586
