Invisible Particle emitter interferes with coplanar visible geometry if Display is not set to Rendered #29695
2 Participants
Reference: blender/blender#29695
%%%Found in Blender 2.61 and r42867, Ubuntu 10.04 x32
In the attached file, there is a particle-emitting sphere that should be invisible (Render Emitter is off in the ParticleSystem settings) inside a glass sphere, but if Display in the Particle settings is set to anything else but Rendered (None, Point, Circle, Cross, Axis), strange effects occur in the viewport. All issues are only happening in Rendered display mode, not when using F12 (unless stated otherwise). The emitters are modeled from a copy of the respective sphere, so visible and invisible faces are coplanar.
Layer 1:
Layer 2:
(Glass sphere with enclosed air, emitter smaller than on layer 1, touching inner boundary of the glass sphere)
In short: If Display is set to Rendered, activating Render Emitter brings the artefacts back, so when Display is not set to Rendered, it behaves as if Render Emitter would be active.
BTW: I also get your "Problem with black lines in win32 renders" ToDo Item - but on Ubuntu 10.04 x32 !%%%
%%%Fixed the particle emitter not being hidden now. However, moire or other artifacts are not considered bugs for overlapping faces, such situations should be avoided, it's undefined then which faces will be rendered in front of the other.%%%
%%%Ok, thanks !%%%
