Cycles: Normal node produces unpredictable results #29715
2 Participants
Reference: blender/blender#29715
%%%In BI, if you add Normal node and calculate dot with Normal output from Material node, Blender shows predictable result with GLSL. By predictable I mean that when you rotate the Sphere in the Node Editor, dark areas in GLSL preview are moving the same way.
However in Cycles when you rotate the Sphere in the Node Editor, dark areas in rendered mode are moving with delay (and probably with value rounding). Also there is no way to light up one half of the object with this material. This problem persists both in CPU or GPU (CUDA) mode.
Blendfile is attached. Switch to rendered mode and rotate sphere inside the Normal node to see the problem.
Tested with Blender svn42880 in 32-bit Ubuntu 11.04.%%%
%%%Fix in svn, thanks for the report.%%%
