Driver's target field doesn't update on Bone rename #29822
2 Participants
Reference: blender/blender#29822
%%%Trying to find out why my driver didn't work, it seems that I've first assigned the driver's target bone (choosing from the ID menu in the Ob/Bone field in Drivers panel, in Graph/Drivers Editor), but renamed this bone afterwards. The driver target field still had the old bone name, didn't update when I renamed the bone, hence not working (without displaying an error or at least the field being red).
It does work on Object rename (e.g. changing the name of the Armature object works, just doesn't work on bone rename).
I'm using current SVN.
Cheers!%%%
%%%Test file needed.%%%
%%%Sorry Ali, attached a file
Well, it might just be a bad flag somewhere, because in a clean file the field becomes red when the bone is not found.
But if you still want to look into this:
Weird fact, if you remove any of the other bones in the armature (I moved them to the back), the field turns red, working properly.
I thought it was a general case, but it might be some weird setup, perhaps not even worth looking into.
Cheers!%%%
%%%Ah... probably this is because the bone rename function only calls the animdata fixit on object-based animation. Let's see...%%%
%%%Fixed in svn.%%%
