Weightpainting with "x-mirror" and "auto normalize" fails for center bones #29832
2 Participants
Reference: blender/blender#29832
%%%While weightpainting with "auto normalize" enabled, the x-mirror code is buggy and that in all combinations (x-mirror, topology mirror, x-mirror + topology mirror). It computes the weights wrong or ignores them entirely. I appended an example file. Just start painting and you will see that it's not mirrored as expected. My current version of blender is r43173.
Typical examples are:
This behavior gets worse and worse with any additional changes to the weightpainting. It's really annoying and currently impossible to use. :-(
Can't it simply calculate the normalized result for one side and then copy it to the vertex from the other side? With copying i mean that .L and .R groups will be switched before transfering the values. This is simple and would always work.
%%%confirmed, looking into it.%%%
%%%I appended a little bit more advanced scenario (added one left and right bone) for testing purposes.
If it works correctly you should be able to paint on "B.L" and "B.R" should show the same but mirrored result. But additionally the groups "A" and "B" should also be mirrored. The last time i painted on the left upper leg (leg-upper.L) i had to notice that the right upper leg (leg-upper.R) was mirrored correctly, but the centered group for the hips (hip) was only changed on the left side and not affected on the right side.
One more thing comes to my mind: If i paint on ".L" oder ".R" groups i noticed that the strength is at best 0.5, even so if set to 1.0. I assume that it is applied as 1.0 but then mixed with the other sides old value, resulting in the average of both groups/sides. I don't know if this is intentional, but from a user perspective the painted weight should be the reference. It sets the value and anything else has to adjust to it, while leaving the currently painted group unaffected.%%%
%%%thanks for the second example, helpted with testing.
fixed r43342. commit log.
also fix 3 other bugs / inconsistencies
this changes normalize behavior - comment from code:
/* note on normalize - this used to be applied after painting and normalize all weights,
Setting as closed but I'd like to know if this makes mirror/normalize workflow work smoothly for you in more complicated cases.
if not will re-open.%%%
%%%I will test it out. Since i have to paint on a stomache with lots of overlapping weight groups (even left bones have little influence on right side, etc.) . That was usually the case in which the weightpainting didn't work as expected. So i will be compiling and do a lot of testing and come back if i find things that aren't as they should be.%%%
%%%I found something. If a vertex lies at a center position (x=0.0) and you paint on a .L/.R vertex group to which this vertex not already belongs, then you will need to click/draw twice before a change is visible. Must be something like: First click assigns vertex to vertex group(s). Second click draws the actual weight to this groups.%%%
%%%This seams also to affect the blur-brush on any part of the mesh. If you just hit on a vertex (neigbour of a vertex beloning to the group) it has no effect. As soon as a vertex that belongs to the group is included in the selection (brush area) it will be luring inside this region. But i don't know how the blur-brush is supposed to be working in weightpaint mode. Does it blur the vertices under the brush (average) or does it blur neighbouring vertices (like smooth in edit-mode)?%%%
%%%fix L/R double click on center verts r43382.
re: Blur brush - it finds the average value from all points under the brush and paints from it - I don;t really like this method much but it works as intended.
