Subsurface Scattering Artifacs #30743
Reference: blender/blender#30743
%%%Subsurface Scattering shows wireframe artifacs wen using backlit thin mesh (shell object) in combination with texturemaps (normal map).
Sreenshot and file attached
Using Blender 2.62 64 bit Windows 7
Blender:
version 2.62 (sub 0), revision 44136. Release
build date: 2012-02-16, 00:08:44
platform: Windows:64bit
renderer: GeForce GTS 250/PCI/SSE2
vendor: NVIDIA Corporation
version: 3.3.0
RAM
12 Gb DDR 3 1600
CPU
AMD Phenom II X6 1055T 2.80 GHz
%%%Brecht, can you please check this?%%%
%%%Developer note: issue seems to be because SSS preprocessing pass is do on non-antialiased buffer. The extra shading points near edges due to AA then don't have a sample nearby in the SSS point cloud, which cause more influence from the back.%%%
%%%Brecht: is this an active open issue on your list, or a known limitation of SSS approximation code, with possible bypasses?%%%
%%%It's sort of a known limitation of the current implementation, you start to get artifacts when the SSS scattering distance is too small because you'd need many points. Moved it to the todo list.
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Render#Render_Engine%%%
