Operator preset save doesn't serialize PropertyGroups *Postponed after 2.63 release*, PATCH ATTACHED. #30905
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#30905
%%%When an operator has a PropertyGroup property (either via a PointerProperty or a CollectionProperty), then preset save (bpy.ops.wm.operator_preset_add) doesn's serialize the PropertyGroup but rather uses its "repr()", which means the preset file then contains 'op.item = <bpy_struct, Item("")>'
Steps to reproduce:
Expected result:
The property group is serialized as a dict
I do not have much time currently but I might write a patch, I found where the preset save is and it is straight python.%%%
%%%This is a known limitation, would be nice to add support though.%%%
%%%At least the system shouldn't create erroneous python scripts. Currently it syntay errors%%%
%%%I wrote a patch, attached here.
Can you review it (coding style, walking method, ...) ? Thanks.%%%
%%%Thanks for writing the patch, will check after release.%%%
%%%applied fix based on your patch r46560.
closing.%%%
