File Output Node does not generate filename only folder #31369
Reference: blender/blender#31369
%%%With "/Users/ronald/Desktop/mask1_" in the Base Path Field of the File Output Node it should generate "/Users/ronald/Desktop/mask1_0001.jpg"
Instead it gives me /Users/ronald/Desktop/mask1_/0001.jpg
Same goes for relative paths: "//../04_Renderings/diff_dir_" generates a folder "diff_dir_" instead of a file "diff_dir_000x.jpg"
This did work in 2.62.
Tested with official 2.63 64bit OSX build and also with a 64 bit linux build (2.63-r46374)
%%%Assigned to myself.%%%
%%%This is correct, the base path is really just a path, it interprets the last part as a folder.
You can add a filename by changing the socket sub-path (in the sidebar, n-key to bring it up). So in your case that would be
base path = "/Users/ronald/Desktop" (or "/Users/ronald/Desktop/")
socket path = "mask_"
You can add multiple sockets with different filenames and/or subfolders in the same base path this way. Documentation for the node is still on my personal wiki page, since unfortunately the node docs have not been ported to 2.6 at all:
http://wiki.blender.org/index.php/User:Phonybone/MultiFileOutputNode
May be worth a design discussion on bf-committers mailing list, but it's not a bug, so closing this report.%%%
%%%Ahh - its a feature - not a bug :)
But it breaks compatibility (at least for me) from 2.62 files to 2.63 :(%%%
%%%Sorry, didn't realize that. I'll add some backward compatibility code to split the previous path into base + file name.%%%
%%%Your reported issue has been fixed in SVN. Thanks for taking the
time to report!.%%%
%%%Thank you for taking time to fix it!
Regards! :)
%%%PLEEEAASSE.... can somebody tell me how to set the "File Path" property (socket) via Python??
This works ok:
py.data.scenes- [x].node_tree.nodes['File Output'].base_path = "ABC"
but I need also to set the file name. Something like this:
py.data.scenes- [x].node_tree.nodes['File Output'].sockets- [x].file_name = ... (doesn't work :( )
%%%In principle what you would do is access the "file_slots" collection (for singlelayer file output) or the "layer_slots" collection (for multilayer) respectively:
node_tree.nodes['File Output'].file_slots- [x].path = "ABC"
node_tree.nodes['File Output'].layer_slots- [x].name = "ABC"
However, i noticed this still crashes due to a general bug :(
Solution for this will require some more digging into and possibly a bit of redesign ... will make a note when this is fixed!
(Dev info: PointerRNA parameter in the "set" callback for RNA properties does not include ID pointer.)%%%
%%%That's what I was looking for but it still says:
'CompositorNodeOutputFile' object has no attribute 'file_slots'
Anyway, I understand there's some work still needed to be done, so I"ll wait. Thank you for v. prompt answer! I Appreciate.%%%
%%%Are you using a recent version? These "_slots" collections were added after 2.63, r46542. In earlier versions the file path would be something like
node_tree.nodes['File Output'].inputs- [x].path = "ABC" (for both single- and multilayer)
Originally the idea was to have the extra info stored as additional socket data. From a design perspective, however, it would be better to make dedicated lists of "slots" in the file output node, and then update the sockets of the node according to those lists. The RNA already implements this as two collections (for single-/multilayer), but it's not yet reflected properly in the DNA data ...%%%
%%%just updated to 2.63a (r46461)
AttributeError: 'NodeImageFileSocket' object has no attribute 'path'%%%
%%%ok, i have downloaded the latest version (from SVN build) and noticed "file_slots". The problem is
... .file_slots- [x].path = "ABC"
makes Blender crash :(
and this
returns:
AttributeError: 'NodeSocketRGBA' object has no attribute 'path'%%%
%%%The first case is what i was describing above (.file_slots- [x].path = "ABC" makes Blender crash). It is supposed to work, but due to incomplete data in the RNA system this still fails. will try to fix this asap.
The second case is not valid code: "inputs" refers to the plain sockets list, which does not directly store the file/layer information for slots any longer.%%%
%%%Fixed the crash problem in SVN.%%%
