inconsistency when setting active uv_texture #31395
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#31395
%%%Assuming we want to activate the uv-set named 'bake', and then bake the textures using bpy.ops.object.bake_image()
The active object should have at least two uv_textures, and the one named 'bake' (having an image assigned) should not be active.
The following works:
bpy.context.active_object.data.uv_textures.active = bpy.context.active_object.data.uv_textures['bake']
while this does not:
bpy.context.active_object.data.uv_textures['bake'].active = True
The attached blend-file should be clear enough. Run either of the scripts without doing anything else. Be sure to reopen the file before running the other.
I expect that they should be equivalent, but on the second variant blender complains that there are no valid images to bake to, even when there are.
Tested on the official build for 2.63a, windows64, as well as a couple of previous releases.%%%
%%%I forgot to mention:
The line seems to work by itself, but it does not work in combination with to_mesh(), like demonstrated in the blend-file, so don't know what exactly causes the problem%%%
%%%I just noticed that if i do mesh.update() right before baking, it works on both versions...
So this might not be a bug after all. I still think it's confusing that the behaviour is different though :)%%%
%%%They both should both work, was just a missing update for the second case. Fixed in svn, thanks for the report.%%%
