BMesh: Knife tool Angle Constraint function #31433
6 Participants
Reference: blender/blender#31433
%%%The BMesh Knife tool Angle Constraint function does not work properly; The cut veers off in one direction or another for a reason I haven't found out yet. This shouldn't need a .blend file; just use the default one and try to get the knife tool to get a perfect straight line(or 45 degree angle line) using the knife tool.
OS Version is Win7 64bit Home Premium
The error has been in Blender since BMesh was intergrated; my current version is 2.63.5 r46549
I've had a few people preform the error as well from a Blender support IRC channel.%%%
%%%Sorry, I forgot to make set the Category to Mesh Editing.%%%
%%%I'm not sure what error you are reporting. Do you know that the angle is in screen space, not model space? Or are you talking about the fact that the snapping can make it not be exactly 45 degrees (though it is close)?%%%
%%%I mean the angle-snapping.
Yes I do know that its viewport and not global.
And sort of; Its not perfect on any of them; see my picture for details on the verticle axis. I was using it for a retopo'ing project that needed straight lines, although it never got actually straight. It got as close as .00001 off, but not perfect, unfourtunantly.%%%
%%%I observed often the same problem rather often.
Sometime when i press C during a knife cut to constraint the angle, it works perfectly and as expected, the cut is indeed constrained to the white line.
But sometime it does not work good, the constrained angle is not exactly what it should be, it is more or less close to the "white line" showed by the constraint when pressing C, making it so you need to find manual non-knife workaround to actually get the cut to occur as desired.%%%
%%%So this is a confirmed bug?%%%
%%%I have this error as well. The endpoint of your cut remains a fixed distance to one side of the constraining line, so that moving out as far as possible is the only way to reduce the error. The problem may be related to the fact that moving the view while angle snapping is enabled causes drastic misalignment, except that it starts out that way even if the face normal is perfectly aligned with the viewport.%%%
%%%I just realized what causes the problem. Error is directly related to whether you start your cut snapped to an edge. If your mouse is slightly off from the point where the cut actually starts (due to snapping), the cut will be offset from the angle constraint by that distance. The solution for now is to start the cut slightly away from the edge, then cut through it. All subsequent cuts in angle snap mode will work just fine; only the first cut has this problem. Hope this gets fixed soon.%%%
%%%Ah, thank you! Will do until its fixed! :)%%%
%%%i confirm the bug in all bmesh builds (last test on buildbot version r47060), thanks for the workaround in the meantime.%%%
%%%I'm trying to reproduce this error and I think I understand what's going on.
To me, there seems to be 2 problems occurring:
I'll check into this.%%%
%%%I should note, it seems to when you place a point to cut from, it at that point seems to decide how how constraints work. So, when you mess up constraints by rotating/panning/zooming, it is reset when you do select another point.%%%
%%%The main problem is that the code snaps to edges and vertices when the cursor gets close to them (even when snapping is 'turned off' - it just does it to a lesser extent). And then it uses some interpolation code to find out where the intersection is. This has to be changed when the angle constraints is on, but I have to figure out the math. I hope to get to fixing this soon (it is first on my plate to fix).%%%
%%%Howard: Mmm, thanks for pointing that out; that makes sense.
Nicholas: Hooray! Someone is assigned! Thanks for helping out! :)%%%
%%%The exact problem is in knife_snap_angle() in editmesh_knife.c. the alignment code is reliant on previous mouse coordinates. The problem with this is that it does not currently correct the "mouse coordinates" to match the screen coordinates snapped-to edges or vertices.
The way I'm trying to approach this is to set the current mouse coordinates cur.mval to the appropriate screen coordinates in knife_update_active().
Handling the vertex snap is relatively simple since KnifeVert has a value for screen coordinates and is given one in knife_find_closest_vert().
KnifeEdge is not so simple because it currently does not store a vertex information. Thus, maybe it would be best to set mval to the snapped location in knife_find_closest_vert() and knife_find_closest_edge() respectively instead of knife_update_active()?
I'm not well familiarized with the code I'm looking at currently so I am not sure the best place to put this.%%%
%%%Just committed a patch, should work as of r48155. :)
Closing as fixed.%%%
%%%Would like to Re-Open, I have found it again in 2.64.9 r52715. Cannot seem to attach video, I uploaded it to dropbox instead; http://db.tt/haoVCS3v . Specs are same as above, but if it helps;
Win7 64bit
Current Blender version is 2.64.9, r52715
Also tested in;
The error persists. Thanks for your help!%%%
