Username with special chars in Windows 7 #31555
7 Participants
Reference: blender/blender#31555
%%%With Windows 7 pro 64bit and blender 2.63a i get an error if my username contains special chars, like "сидорович" (russian). Output follows:
found bundled python: C:\games\blender-2.63a-release-windows64\2.63\python
py", line 484, in user_resource
4, in makedirs
4, in makedirs
4, in makedirs
4, in makedirs
4, in makedirs
4, in makedirs
4, in makedirs
2, in makedirs
WindowsError: [Error 5] Access is denied: 'C:\Users\С\u201eРёС\u201aР°С\u040fС
\u2021'
I get this error when installing some plugin (in fact just pressing ctrl+alt+u>addons>install addon>ok button). If i try to save or load my work i see an empty:
C:\Documents and Settings\
Even if i have users written only with normal symbols like "james" or "brown" and my testuser "сидорович" in the same folder.%%%
#39917 was marked as duplicate of this issue
#38998 was marked as duplicate of this issue
#38357 was marked as duplicate of this issue
%%%note that this was a problem on linux too but its been fixed now, on windows Im not sure why it persists but the error looks to be caused by bad encoding?%%%
%%%Will try to reproduce on my laptop.%%%
%%%Can confirm it's not fixed on windows.
Seems that issue happens in bpy_user_resource function: BLI_get_folder returns folder in cp1251 codepage in this case. Probably just converting path to utf8 would help. But maybe this is supposed to happen from python's side?
Anyway, even if that's supposed to happen from python's side, subdir is passing in utf8 but BLI_get_folder still works with cp1251 and this might cause some issues.
Campbell, can you please look into this?%%%
%%%I just tested with the name "сидорович" and this works for me on windows XP, creating a dir.
Both...
bpy.utils.user_resource('SCRIPTS')
bpy.utils.user_resource('SCRIPTS', create=True)
@wintch, its possible when copying out of a web browser the encoding is changed, could you make an empty directory with this name, zip it, and attach to this post?%%%
%%%ok, there is an attachment.%%%
%%%The issue is in fact that environment variable is ignored on windows:
I've committed a workaround for now, which is to manually force the encoding:
PyRun_SimpleString("import sys, io\n"
"sys.stdout = io.TextIOWrapper(sys.stdout.buffer, encoding='utf-8', errors='surrogateescape', line_buffering=True)\n"
"sys.stderr = io.TextIOWrapper(sys.stderr.buffer, encoding='utf-8', errors='surrogateescape', line_buffering=True)\n");
Whats most strange is that when running blender from a console (cmd.exe) calling this befor starting blender works:
set PYTHONIOENCODING=utf-8:surrogateescape
I tried calling BLI_setenv at the beginning of blenders main() to ensure its set early enough, and printed the value to make sure its being set properly, but its set, just python ignores it.
setting as a TODO since this is really a workaround and not a fix.%%%
%%%The workaround caused bug [#32720], reverted the workaround and re-opening this one.%%%
%%%For the record, this is the corrected line, that doesn't cause [#32720], but it an assert() in MSVC90.DLL when quitting blender, so Im not going to apply it.
"sys.stdout = sys.stdout = io.TextIOWrapper(io.open(sys.stdout.fileno(), 'wb', -1), encoding='utf-8', errors='surrogateescape', newline='\n', line_buffering=True)\n"
"sys.stderr = sys.stderr = io.TextIOWrapper(io.open(sys.stderr.fileno(), 'wb', -1), encoding='utf-8', errors='surrogateescape', newline='\n', line_buffering=True)\n");%%%
%%%Mailed python developer list on this issue.
http://mail.python.org/pipermail/python-dev/2012-October/122052.html%%%
%%%closed duplicate [#32750]%%%
%%%Submitted a patch to python3.4, the issue is open in their tracker:
http://bugs.python.org/issue16129%%%
%%%Python guys dont seem interested to give a way for us to set the encoding for sys.stdout short-term.
So temp workaround is to start blender from a .BAT file and set your environment variable from that.
blender.exe
setting as todo since this is a python issue and its reported in their tracker.%%%
%%%re-applied workaround r52739. closing.%%%
%%%removed workaround, it stops the stdout from being writable on exit (no memfree prints)%%%
%%%duplicate reported [#34189]%%%
%%%an additional info to the issue described in [#34189]:
i noticed, that there is no that issue, when i am in an environment of
windows 7 sp1 64bit (german version, german keyboard layout / german as default input language)...
that issue i can only reproduce on that environment:
windows 7 sp1 64bit (english version, german keyboard layout / german as default input language)%%%
%%%I get the same issue as Alexander. I'm trying to import OpenStreetMap data and printing to the console but \u2019 (right special quote) crashes out. To reproduce:
UnicodeEncodeError: 'charmap' codec can't encode character '\u2019' in postiion 13: character maps to
Win8 x64 english 2.66%%%
%%%duplicate reported [#36642]%%%
Forgot to say it here, but a patch allowing to fix once and for all that kind of issues has been accepted in python3.4, which final version is expected on February 2014, so we should soon be able to fix this old bug!
Added subscribers: @GaiaClary, @djnz
◀ Merged tasks: #38357.
Added subscriber: @Montaire
◀ Merged tasks: #38998.
Added subscriber: @YonghaiYu
◀ Merged tasks: #39917.
This issue was referenced by blender/blender-addons-contrib@bb5b608deb
bb5b608deb
Closed by commit
bb5b608deb
