Remesh modifier generates different results depending on object origin position #31626
2 Participants
Reference: blender/blender#31626
Relates to: #31111
%%%Currently Remesh modifier voxel size depends on the following expression:
voxel_size = max(ob.dimensions) / mo.scale / 2 ** mo.octree_depth
When the object origin lies inside the object bounding box, max(ob.dimensions) is the max size of the bounding box in local coordinates.
In this case the voxel_size does not depend on the position of the object origin.
When the object origin lies outside of the bounding box, max(ob.dimensions) considers the position of the origin as well.
In this case the voxel_size depends on the position of the object origin.
See attached example: the five boxes are identical, the same Remesh modifier is applied.
The resulting modified cubes are different:
IMHO a proper and dependable implementation would require:
mo.scale and mo.octree_depth properties should be replaced by mo.voxel_size;
or use a fixed reference lenght instead of max(ob.dimensions), e.g: 1 Blender unit.
object origin should become the reference point for the voxelization.
In other words: one voxel center always lies at the object origin.
Tell me if further research is required.
Thank you very much and best regards,
Emanuele Gissi%%%
%%%Thanks for reporting, the bounding box calculation had an initialization bug. Fixed in r47443.
I'm taking another look now at making the suggested "voxel_size" property change. Since that is feature change rather than a bug, I'm closing this report and will email you about it directly.%%%
