setGLSLMaterialSetting has no effect #31757
6 Participants
Reference: blender/blender#31757
Category: Python
%%%SetGLSLMaterialSetting is not working on Blender higher than version 2.59.
I have tried it with lights, shadows, shaders and extra_textures, no parameter is working.
Tested with Blender:
2.59 = working
2.62 = not working
2.63a = not working
2.63.10 = not working
Windows XP 32 Bit
Intel Q9300
Nvida GeForce GTX 460
Attached is a Blender 2.59 example.%%%
%%%confirmed (the file is missing its textures btw).
In 2.59, however, the GLSL setting is left 'alive' even after we quit the bge.
I think this was introduced when I fixed exactly that (with the GlobalSettings patch). I will investigate%%%
%%%ok I found the problem. In gpu_material.c Blender is checking for the flags in the mat->scene, not in the globalsettings.
Since this is a shared function for both BGE and Blender I'm not sure what is the best way to solve that.
One option is to store in KX_Scene the original flag and re-set Blender flags when we leave BGE.
Brecht, do you have any suggestion on a clean way of solving this?
For the records, the patch below reproduce 2.59 behaviour:
Index: source/gameengine/Ketsji/KX_PythonInit.cpp
+++ source/gameengine/Ketsji/KX_PythonInit.cpp (working copy)
@@ -1169,6 +1169,10 @@
(and also confirmed that the bug was introduced with the fix in rev. 40113)%%%
%%%I change the place of your changing from line 1169 to 1154, because otherwise switching on and off is inverted.
Index: KX_PythonInit.cpp
+++ KX_PythonInit.cpp (working copy)
@@ -1154,6 +1154,10 @@
else
gs->glslflag |= flag;
if (sceneflag != gs->glslflag) {
GPU_materials_free();
%%%This indeed seems to be the easiest solution, I'm ok with this fix.%%%
%%%Should this be closed?%%%
%%%hi Angus,
this can't be closed (no commit was done to address that). I'm assigning to Mitchell in case he wants to implement the solution discussed above.
(the above patch + the changes in KX_Scene to store the initial glsl settings, although that requires testing).%%%
%%%The problem isn't fixed until now.
Is there someone who can investigate into this problem?
It seems to be solved by Dalai Felinto and HG1, but it's still not fixed in trunk.
It would be very cool if someone can fix it.%%%
%%%I'm assigning this to Dalai; I never took much of a look at the patch.%%%
%%%Hi,
is there any possible fix for the function now?
I would like to see a function which works. :)
Thank you guys for investigating.%%%
%%%The mentioned fix from HG1 works perfectly.
I'd updated it for the newest revision.
@@ -1182,7 +1182,13 @@
gs->glslflag &= ~flag;
else
GPU_materials_free();%%%
%%%patch committed on rev. 56605
thanks everyone for contributing to that.
Sorry about the long delay, but I've been too busy lately%%%
