DopeSheet - Grease Pencil mode collapses visible channels when switch channel #31930
Reference: blender/blender#31930
%%%checked in Windows XP and Win 7
Blender v2.63
This is really annoying. Unlike using the dopesheet for animating poses, the channel group display collapses the open/ visible channels whenever you select a different channel using the properties panel when using the grease pencil mode of the dopesheet. Since multiple channels are often necessary when animating, you must switch between channels as you build the scene. BUT each time you start to draw in a different channel, the dope sheet display of the group of grease pencil channels collapses, so you must constantly re-open it to see which channels you have completed for that keyframe.
For example: In the enclosed blend, the grease pencil group/ unique data block named Director is visible but no keys are visible. Click to open it in the dope sheet/ grease pencil mode and select a channel, eg Action and you can see all the keys in all the channels. Now IN THE PROPERTIES PANEL select a different channel, eg Camera. Look down and you see none of your keys as the whole group of channels has been closed. You must use the properties panel to select the channel you are editing because selecting it in the dope sheet will NOT change the channel you will draw with next., i.e. if you select Camera in the dope sheet, after selecting Action in the properties panel, you will still draw in the Action channel, not in the Camera channel.
The last point, not switching working channel when selected in the dope sheet, is not a big deal, Please just get properties panel selection to leave the working channels open so we can see what we are doing.%%%
%%%To clarify what's happening in the provided .blend, in 3D View's properties panel when you select any grease pencil layer (including the currently active layer), it toggles the visibility of corresponding grease pencil grouped channels (layers) in the DopeSheet. This happens regardless of whether Grease Pencil is the active mode for the DopeSheet.%%%
%%%A similar effect happens when doing by undo/redo, but not add/delete layers in the properties panel.%%%
%%%Something weird is going on here. It seems that the Director channel (gpd) is only expanded when even-numbered layers are visible. %%%
%%%Ah! It was just a typo.
Fixed in svn.%%%
%%%Confirmed the fix. The last bit is more of a feature request, so I'm going to go ahead and mark this as closed.
Thanks for the report. :)%%%
%%%Eep, sorry, page refreshed with the status set to "new". Must have retained it from history.%%%
