Metaball used as render object(group) for particle will display wire only. #32034
Reference: blender/blender#32034
%%%When I try to assign the metaball as render object for a particle system. The particle will not display the replacement object (in this case should show up those metaballs) but some circle wire. Please check the attached two files.
My env:
Blender v2.63 official download from blender.org r46461:46487M
Regards,
congcong009%%%
%%%I took a look at the files and see what you are talking about. Not exactly sure what is going on here, but the mball seems to show up fine in edit mode, just not in object mode.
Something seems off :(%%%
%%%Also, I just noticed that if I lower the view or render resolution to its lowest of .050, they start showing up in view and render better. Hope that helps whomever investigates this!%%%
%%%It's indeed not a bug -- it's just resolution is too high to rasterize such small metaballs. Reducing view resolution is indeed the way to deal with this.
Thanks for the report, but it's not considered a bug.%%%
%%%Actually, the issue in this case was deeper and was related on dependency graph. This should be fixed in rev48858.
But issue with resolution is still valid -- be aware of it, otherwise it'll be easy to miss your metaballs.%%%
%%%What fixed this bug for me was: uncheck scale from the particle object in the emitter settings%%%
