inconsistent behaviour of the UV-editor while assigning uv textures. #32576
Reference: blender/blender#32576
%%%In the attached .blend file you find 2 cubes.
Both cubes have been unwrapped.
The left cube has just been assigned to a test pattern.
I have enabled "textured solid" and you can see the texture is correctly applied to the cube.
I have switched to object mode and seklected the other cube.
After you have opened the .blend file,
You also see the test pattern in the background of the UV-editor,
although the test pattern is not assigned to the object (as can be seen in the 3D view)
I expected to see the UV-layout on a grey background (to indicate that no image has been assigned yet)
Further more: If i now want to assign the test pattern to the right cube,
then i have to select the pattern although it is already selected in the UV-editor.
Furthermore: If i now click on the unlink-button then the just assigned image gets deassigned again (expected)
but when i now switch back to the cube on the left, then enter edit mode, then i see a grey background instead
of the testpattern.
This behaviour was different in older releases. there the currently selected uv-texture was always
displayed correctly as soon as i entered edit mode.
I tested on windows-7
build 50699%%%
%%%Confirmed.
Developer note:
In my opinion the behavior of this functionality is a bit ambiguous. For instance, how do we handle multiple images on a mesh when all faces are selected? Do we display the image that belongs to the active face?%%%
%%%It's just a missing notifier update, fix in svn. It's indeed the active face that is used to determine the image, can be a bit confusing at times, but it's already done this for 10 years or so :)%%%
