Important memory usage with video textures #32795
2 Participants
Reference: blender/blender#32795
%%%Hi all,
I discovered that if you use a video as a texture for a plane, the memory usage will increase as the render of the final movie progresses; leading to a total consumption of the system RAM, and eventually a crash.
It appeared with 2.64 (the memory usage for the same render stayed very low on 2.63a).
Steps to reproduce this:
Same problem with animation preview.
OS: Debian testing 64b
3D card: Nvidia gtx550 Ti
Problem exists in: Blender 2.64 (r51026) (64bits) and Blender 2.64RC2 (r50890) (64bits) but not in 2.63a (r46461) (64bits)
Thanks
Oygron
Attached, a .blend (without the video) to reproduce the problem%%%
%%%Using Debian Testing 64bit as well and can not see memory issues here. Was using tears_of_steel_1080p.mkv
Couple f questions:
%%%Hi,
I'm using builds from blender.org, and tears_of_steel_1080p.mkv too.
It seems to happen with every video I tested, the higher the quality of the video is, the quicker the memory usage increases with the number of rendered frames.
After 1000 rendered frames, using Tears of Steels, my memory usage of Blender (2.64) was 2Gb. After 3000 rendered frames, Blender used my whole RAM (8Gb) and my system began to swap.
With blender 2.63a, it was still at around 200Mb.
I hope these pieces of information will help.%%%
%%%Could you please do one more test: load factory settings and see if it helps.%%%
%%%Same problem after reseting to factory settings.
While looking if my bug hadn't already been reported, I found this:
http://projects.blender.org/tracker/?group_id=9&atid=498&func=detail&aid=32465
It seems very close to me, but not exactly the same. Couldn't there be a related cause, video caching enabled by mistake for several type of objects, and then disabled only for nodes and not for textures?
It is probably a wrong way, but as it reminded me my problem...
Thanks%%%
%%%No, you can not enable cache for some particular datablock only. It's also quite strange why the issue isn't reproduceable here on the same debian testing, the same release build. Would test on home desktop as well, maybe i'll have more luck there.%%%
%%%Some more puzzling facts:
It seems to tell me that it is a problem with my video encoder, but why does it appear only when videos are included? Why not on the 2.63? Why not on your computer?
My mind is blowing...
Thanks for your explanations and the time spent on this.%%%
%%%Blender from official site is using static linking against almost all libraries, so doubt issue is in your video encoding libs.
Could confirm the issue now with rendering to h264 video. Now i can look into it :)%%%
%%%Fixed the issue in svn rev51184. Fresh builds should arrive to http://builder.blender.org/download/ soon. Please report back here if the issue will still exist for you.%%%
%%%No more problem on my side!
Thanks a lot, you're great!%%%
%%%Cool to hear this! Thanks for the report btw :)%%%
