modules/rna_xml.py: "Size Mismatch!" with different collections sizes #32882
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#32882
Relates to: #31703
%%%When using xml2rna from the rna_xml module, the import is aborted when a bpy_prop_collection in the xml has a different length than in the current file.
For example, as in the attached file, xml2rna into a fresh new .blend doesn't work.
The workaround proposed in #31703 ( http://projects.blender.org/tracker/?func=detail&atid=498&aid=31703&group_id=9 ) doesn't work because prop collections do not have an .add() method.
Reproducing: Open the attached .blend and run the script (xml2rna.py), even though the XML refers to data on my computer, the Size mismatch! message will display before.%%%
%%%Campbell, can you please check on this? Thanks!%%%
%%%Hi Simon, The XML presets were intended as a way to store settings without having to execute code - supporting vector collections is useful too but not really a bug.
As in - adding support for this is fine but at some point you hit a limitation with xml2rna.py not being able to restore entire datablocks / blendfiles.
Having xml2rna.py as an alternative to the blend file format is outside the scope of this py module.
Closing this bug but adding it to the python TODO wiki.
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Scripting#General_todo_items
