New Bevel's issue with Edge Split modifier #34445
Reference: blender/blender#34445
win32
r54862 - the issue
pre-new Bevel modifier - worked good
The new Bevel Modifier works worse than older when using it with Edge Split (set to Sharp Edges).
Just open my .blend or look to pictures.
I suggest to add splitting edge just on borders of bevels. If it's not possible with Segments >1 then at least make it for 1.
Now some important lyrics. Read it only if you're disagree with current Bevel -> Edge Split behavior.
I think I can talk about a kind of regression.
The old Bevel modifier was really good (see the picture with *_old) to quickly prepare mid-poly meshes for baking to low-poly.
Using the modifier of bevel here gives a good freedom to change it when you need. That's really good because the texture size is limited.
When you set some small bevel here is always a possibility that it will be too small on a texture after baking.%%%
%%%Thanks, I'll look into this.%%%
%%%closed duplicate [#35616]%%%
%%%Ooops! Sorry, Howard! I've didn't meant to push on you.%%%
%%%I looked at this bug again. What is needed is to look at the original 'smooth/not-smooth' edge header element, and copy it to appropriate edges in the edge bevel. I'll get to this later, but recording here what needs to be done.%%%
%%%I believe revision #58076 fixes this.%%%
