When Material Options > Surface is active with complex node network, viewport slows down significantly #35051
2 Participants
Reference: blender/blender#35051
Windows 7, gtx 580
Buildbot : r55223 - Error
Buildbot : r56100 - Error
Buildbot : r46883 - Error
significant viewport slowdown when surface info is visible in material settings on complex node networks
%%%To fix slowdown, switch out of material tab to something like the object data tab or physics tab or something... it seems that you can switch back to the material tab and viewport performance is still good... its just that first initial viewing of the surface material.
%%%If you expand all node sockets in the material properties then indeed things will be slow, all I can suggest is to avoid doing that for complex node networks, viewing a graph as a tree view gives many duplicated nodes. Viewing the nodes is mainly meant for simple node setups or cases where you create group nodes to hide that complexity and present a simpler view in the material properties.
Navigating the 3D view shouldn't be causing the material properties to redraw though, will figure out why that happens.%%%
%%%There was a problem handling such huge panels, which was causing the properties editor to continuously redraw. Fix in svn now, thanks for the report.%%%
