Bullet Convex Hull Crashes on Win32 with SSE #35071
Reference: blender/blender#35071
Category: Physics
Windows Vista 32-bit, Intel 495
trunk @ r56277 crashes when starting the game engine with the attached .blend
Loading the attached .blend and starting the Game Engine crashes Blender (~ 80% of the time)
The scene consists of static body and a dynamic body with a Convex Hull collision box.
Note 1: If the collision box for Suzanne is changed to a non Convex Hull type there is no crash.
Note 2: Tracing shows that the crash seems to be related to SSE support in bullet WHEN embedding bullet aligned-classes (btVector etc) in non-aligned external classes.
Note 3: From the btScalar.h header
//---snip--
- define BT_USE_SSE
- ifdef BT_USE_SSE
BT_USE_SSE_IN_API is disabled under Windows by default, becauseit makes it harder to integrate Bullet into your application under Windows
*(structured embedding Bullet structs/classes need to be 16-byte aligned)*with relatively little performance gain
If you are not embedded Bullet data in your classes, or make sure that you align those classes on 16-byte boundariesyou can manually enable this line or set it in the build system for a bit of performance gain (a few percent, dependent on usage)
#define BT_USE_SSE_IN_API---snip---
#endif
%%%This issue might be related to http://projects.blender.org/tracker/index.php?func=detail&aid=35048&group_id=9&atid=306%%%
%%%Hmm, this looks fishy.
Seems like those defines were added in this commit: http://code.google.com/p/bullet/source/detail?r=2634
Don't really see why though.
As far as I can see it should be safe to remove them.
In my tests using SSE had only small benefits, but that depends on the scene and the processor of course.%%%
%%%I downloaded an actual version from the Buildbot and it works without crash.
But when I building Blender (Windows XP 32 bit with Microsoft Visual C++ and SCons) from the actual trunk, Blender will crash without this fix.%%%
%%%I committed Francisco's fix in svn r56519.
Could you test if the problem is fixed now?%%%
%%%It seems the problem is fixed, closing.%%%
