Could not open .blend file with chinese in path #35081
5 Participants
Reference: blender/blender#35081
%%%Windows 7 Pro,GTX 580
Blender version with error:2.66 buldbot r56296
and version that worked:2.62
Short description of error:Could not open .blend file with chinese in path
Steps for others to reproduce the error (preferably based on attached .blend file) :
Try to open the blend file in attach files folder.
PS:saving is ok,image file is ok.
%%%Tried to reproduce the issue, no luck. Eevn failed to updack the archive -- seems path name is messing up. However, ussing russian (which is also multibyte) letters in paths works just fine.
Anyone succeeded to reproduce the issue?%%%
%%%I can reproduce this everyday for months, as well as almost every Chinese Windows blenderers I met. It has been reported similar issues long time ago.
http://projects.blender.org/tracker/index.php?func=detail&aid=32888 (todo?)
http://projects.blender.org/tracker/index.php?func=detail&aid=30751 (not really fixed)
http://projects.blender.org/tracker/index.php?func=detail&aid=30752 (fixed)
Since Linux can deal well with with IME and non-ascii paths now, I think it's more like a OS-related issue. I've attached 2 images to show how weird the character displays in console window.
However, one quite interesting thing is: If you added 5 ASCII characters ( doesn't work if less than 5), it will work. Like what's like on my image. I don't know if this is only for CJK. Some other reference, if helps: http://stackoverflow.com/questions/5865430/cross-platform-input-method-support
To be honest, we are really dreaming for such support!%%%
%%%I can reproduce the reported issue on Windows Vista x64 with the active code path set to 932 (Japanese Shift_JIS).
Blender cannot open .blend files if they are in a folder whose name starts with a Japanese character.
The error pop-up window shows the full path to a .blend file correctly (including Japanese characters in the path), but Blender fails to open the file.
As Leon reported, .blend files can be loaded without trouble if they are in a folder whose name starts with 5 ASCII characters followed by Japanese characters.
The pop-up window error message "unable to open the file" seems to come from wm_read_exotic()'s return value BKE_READ_EXOTIC_FAIL_OPEN.
This value is returned from wm_read_exotic() only when BLI_gzopen() fails in that function.
Apparently there is something wrong in BLI_gzopen() with regard to gzopen() or GetShortPathNameW() called from there (involving encoding conversions between utf-8 and utf-16 back and forth).
I am not familiar with these Windows specific file name handling, but a solution here could be to rely on gzopen_w() available in zlib 1.2.7.
See the attached gzopen_w.patch to fix the reported issue. With the fix and updated zlib everything looks working well on my side.%%%
%%%> Windows Vista x64 with the active code path set to 932 (Japanese Shift_JIS)
I meant the active code page (i.e., system locale in Windows).%%%
%%%I did some investigation too(although I not a real coder):
1.Output come from
In this fucntion of "wm_files.c"
static int wm_read_exotic(Scene *UNUSED(scene), const char *name)
the line with:
gzfile = BLI_gzopen(name, "rb");
2.BLI_gzopen function of "fileops.c"
It will call "BLI_get_short_name(short_name, filename);"
before "gzfile = gzopen(filename, mode);"
I think why the first 5 ASCII work is because it still valid after windows shorten path.
make a little printf,the filename and the short_name is:
filename : D:\FileInChinesePathCanNotOpen\娴嬭瘯鐩綍\test.blend
short_name : D:\FILEIN~1\K疹U\TEST~1.BLE
Maybe ENCODE?%%%
%%%I want to try Tamito Kajiyama's patch.
But can you tell me how to update to zlib 1.2.7?%%%
%%%Hi Harrison,
You need to build zlib 1.2.7 from the source. I relied on CMake to build it in the Release configuration (just in the same way with Blender build).
After a successful build, you will get zlib.dll, zlib.lib, and zconf.h in the build directory. You also have zlib.h in the source directory.
Copy library and header files into the lib/windows/zlib/include and lib folders, respectively, by hand (or lib/win64/zlib in case you have 64-bit Windows).
You also need to change the file name of zlib.lib to libz.lib. Then build Blender as usual and install it (to get the DLL updated). That's it.%%%
%%%The patch is correct. I committed it now along with 32 bit zlib libraries, and added an extra check so it keeps compiling on other platforms until zlib has been updated for them.
Now we just need updated 64 bit and mingw libraries.
%%%We now have 64 bit zlib libraries as well, and the (non-experimental) buildbot builds should have the fix:
http://builder.blender.org/download/
Please test if they work for you.%%%
%%%Hi Brecht,
Thanks for the commits. I confirm that the updates work fine on my side.%%%
%%%It works fairly well with Chinese character path. Thanks a lot guys!%%%
%%%It works very well,thank you all!%%%
