Collada: export destroys mesh in some cases #35555
Reference: blender/blender#35555
here Win7 32 Bit, GeForce GTX 460/PCIe/SSE2/3DNOW!
But other People have the same problem
2.66a worked well. 2.67 and 2.67a have the problem
In some cases vertices are wrong connected after collada-export.
Example1:
Example2:
(helpful to do this is to switch to Transformorientation "Normal")
(See the example-Object "Example_2" in blendfile)
%%%Hi Gaia! Afraid you're the only who could really easy resolve the issue. We'll really appreciate your help here :)%%%
%%%Works for me.
Please can you provide:
thanks%%%
%%%The problem occurs, when in collda-export "Triangulate" is activated. See the pic in the 2nd Attachment.
When i activate the "Export for SecondLife"-Option, than the problem occurs inworld
in both cases: With and without "triangulate"-Option.
The workaround for SecondLife-Upload is at the moment:
Attach the triangulate-modifier to the object: Without APPLY.
Instead activate in the collada-export-options "Apply Modifiers".
%%%The internal-uploader don't work. I get errors. So i use pasteall.org:
The Blendfile:
http://www.pasteall.org/blend/21723
The oicture for collada-settings:
http://www.pasteall.org/pic/52438
%%%The problem is in the triangulate function. Investigating...%%%
%%%Hi, Ideasman_42;
I have added a blend file which contains 2 ngons for comparison.
Both ngons behave differently:
the left object exports wrong, and shows broken triangles on re import.
the right object exports correct and can correctly be re imported.
the export/import fails only when the export option "triangulate" is checked.
When triangulate is disabled, then ngons always export/import just right.
Observations:
1.) the vertex order of both objects is different. hence the normals show in opposite direction.
2.) for the broken object, the function poly_find_ear() always returns NULL
3.) I think that the function poly_find_ear() will fail if the order of vertices in the mloop is not clockwise (or anti clockwise)
4.) right after triangulation, the resulting Mesh object already contains the wrong triangles.
5.) The problem is somewhwere in / below bc_triangulate_mesh() (in the collada module)
Further: The right object (working) has been created manually. I just created an edge loop and then filled the loop.
The left object is a copy of the OP's initial demo, but reduced to just one ngon.%%%
%%%face normals were not calculated, added an argument to the conversion function for this and asserts so the error is much more obvious next time.
fixed r57208.%%%
