UI does not update as expected - (context is wrong - update is delayed) #35600
7 Participants
Reference: blender/blender#35600
system1: Windows 7 64bit, i7-3770 internal GPU (HD4000)
system2: Windows 7 64bit, AMD HD5670
blender-2.65a-windows64, with issue;
blender-2.66a-windows64, with issue;
blender-2.67b-windows64, with issue;
the user interface (UI) is not updating its content and its list item source context as expected - its update is delayed.
in my case, especially visible, when you have an armature and you add an "inverse kinematics" bone constraint to a bone and choose an armature as target.
than the IK control panel changes directly under the mouse cursor. when you now try to select the bone within of that armature, it can happen, that a wrong list of available items will be shown to you.
see the attached video...
(2. change to edit mode)
(3. add some bones)
... the "Armature" list entry is directly at the position, were the "Bone" subtarget will appears.
... leave the mouse cursoe at that position or do not move the mouse cursor too far after selection of "Armature".
... it seems, that not all content/context is updated/refreshed at the same time. visually the ui is updated, but its mouse click events receives old positions of the controls as they were before the subtarget control appears.
the situation will get normal (visual and underlying context will be the same) just when the mouse cursor will cross the border of an control region. that will trigger an update/refresh of all stuff to get sync
(... thats what i think.)%%%
%%%I can not ever redo it, checked the video (saw error) and used your blend file. The steps you write are not fully clear to me though. Here is my version:
Always goes ok. (Mac osx 10.7, release and current svn)
It is as if the mouse coordinates go wrong after using a menu?%%%
%%%i installed Linux (ubuntu 13.04) and blender 2.67b (blender-2.67b-linux-glibc211-x86_64.tar.bz2) on the same system as system 1.
i can NOT reproduce the first issue of the video of the IK constraint and the subtarget list.
BUT: i can reproduce the second issue of the video - when renaming a bone, its name in the outliner is not updating immediately.%%%
%%%i tested on a third system:
system 3: Windows 7 64bit, nVidia Quadro FX 570M
there i can reproduce all the issues again.
conclusion:
system 1: Windows 64, i7-3770 internal GPU (HD4000), blender-2.67b-windows64.zip
system 2: Windows 7 64bit, AMD HD5670, blender-2.67b-windows64.zip
system 3: Windows 7 64bit, nVidia Quadro FX 570M, blender-2.67b-windows64.zip
are having both issues, the first in the IK constraint and the second with the delayed bone renaming in the outliner
system 1a: Ubuntu 13.04 64bit, i7-3770 internal GPU (HD4000), blender-2.67b-linux-glibc211-x86_64.tar.bz2
is having only the second issue with the delayed bone renaming in the outliner
%%%The delayed bone renaming is completely unrelated, that is a missing redraw signal.
The first issue seems to me a bug in how the Windows version handles mouse coordinates after using a popup.
You should be able to redo similar issues for any button that pops up menus?%%%
%%%the first issue i could only observe on that inverse kinematic constraint.
i think it is a very specific issue and is very depended to few situations.
a popup (list) overlays an text field
(the list of KinematicConstraint.target overlays the textfield of KinematicConstraint.pole_target)
selecting an item in that popup must result in a change in of the panel under the popup, exactly at the same position, where the selected list item was and you released the mouse button. in my case, you must select an item that
a.) is at the first position in the list and
b.) must have sub items, that cause to add an extra text field to the panel
(when you select the first item in the list, the mouse cursor is exactly over the position of the ".pole_target" text field. if the selected item is an object with sub items, e.g. Amature has bones as sub items, an additional text field appears exact under the just selected list item - under the mouse cursor, where the ".pole_target" text field was before.)
after selecting the list item, the popup overlay disappears and the mouse cursor is now in the just newly appeared ".subtarget" text field.
when you DON'T leave that text field region with the mouse cursor, you will see the wrong popup list from the ".pole_target" instead of the ".subtarget".
(when you want to get the correct popup overlay (list) of the ".subtarget", you must leave the border of the subtarget text field region first - then you can see list that you expected)
i tried out several other constraints (all pose bone constraints), but i didn't found any other similar constraint/panel/situation where all these dependencies/constellations came together - my blender knowledge is not so good, that i knew other panels with the same constellation of popups and panel changes.
any suggestions, that panels i could test?
(from previous posts i know, that my english is not very well - but i always try to describe an issue as detailed and precise as possible - with the risk, that my description will be more confusing than helpful - sorry, but i can't explain complex things easy with limited english knowledge)%%%
%%%i tried to provoke this first issue, by rebuild a similar panel with similar conditions by script (see the attached "ui-update-issue test v1.blend" ).
but without success, whit that i can NOT reproduce the behavior of the issue...
when i change the "Row 1" in the same way as in "IK constraint" and open the new appeared "Row 2", i get the correct list of bones to see... ?!?!
... any other ideas?
... did somebody else observe the same behavior - or is it only me?%%%
%%%... attached a video "Ui-update-issue Test V1.mp4" for previous post (Date: 2013-06-08 08:37)%%%
%%%The tracker is flooding with issues, but I noticed your updates. We just need someone using Windows to dig into in the issue.%%%
%%%thanks Ton, ya i saw in the dev meeting notes, that there are many open issues - when the masters ask for more reports, the audience is following the call ;)
in the meantime i run a additional test with "blender-2.67b-windows32.zip", only to see if the issue is 64/32bit build related.
but is happens also with that version - so, it is not related to 64/32bit build.
i didn't know, that windows devs are so rarely at BF - maybe now i know, why the windows build bot is currently not as up to date as the other builds...
for that "exotic" OS, the windows build works very well (i know other open source projects where the windows build is a mess compared of the linux one).%%%
%%%ok its to to get, but i can reproduce this little refresh error, when i do not move my mouse after clicking armature
win 7 64bit (ger)
blender 2.67b r56533%%%
%%%Confirmed the bug on Windows 8.
The "Armature" lookup that shows up is in fact the one for the "Pole Target" (as kind of described above, but I just wanted to make that clear).
So even though my mouse is over:
"pose.bones["Bone.001"].constraints["pose.bones["Bone.001"].constraints["Const"].pole_target"].subtarget"
What I get in the lookup (or if I RMB click + Copy Data Path) is in fact:
I got a dev environment on Windows here, if there is something I can try let me know.%%%
Added subscriber: @Sergey
Does it still happen with 2.69 release and current development builds from http://builder.blender.org/download/ ?
yes, all issues are still there with "blender-2.69-15f449c-win64.zip" on Windows 8.1 64 bit
(the issue with the IK constraint, and the issue with delayed updating name)
Added subscriber: @mvgulik
The delayed updating issue seems similar to what I'm seeing. So adding my comment to this bug report. (not familiar with all the bug search features/inputs)
From a visual point of view it seems to me that the video display is flipping between showing the final screen AND the last buffered/previous screen. (when moving the mouse paste some UI area border)
Issue as of Blender 2.65. (that's 2.65.?|zero, aka: the one before 2.65.A)
OS: Windows XP
Video: Intel 82915G/GV/910GL Express Chipset Family (old and kinda bugged intel product)
I'm not a real Blender user. Just have it installed/available as potential on the side tool. But have not used it in a long time now. (never got comfortable with finding my way around the Blender UI)
Added subscriber: @mont29
FYI,
295bc1249a
fixes the outliner refresh issue.@beta-tester could you please check whether issue is still present in latest master (builds from our buildbot)?
For what it's worth. UI seems to be back to normal on this side.
Ok, will assume this one is fixed for now.
@mont29: oh, sorry, i did not noticed that you asked me something...
(most of the developer email notifications are classified as spam in GMX.)
i just tested it with the recent build bot version:
blender-2.71-4f7caab-linux-glibc211-x86_64.tar.bz2
and
blender-2.71-35bc266-win64.zip
YES, it is fixed thank you.
