list items in properties editor #35750
5 Participants
Reference: blender/blender#35750
properties list items ( like vertex groups list ) dont use interface theme list items text colors
see attached image
%%%Dev note:
In interface_templates.c in uiTemplateList()
some of the "layout_type" cases define a custom but and pass over the "LISTROW" type, so the list theme works, others use a draw_item(). %%%
%%%Assign to self!%%%
%%%I move it to Brecht's desk. He coded most of it, might now smarter solutions.
Currently, the only lists in Blender respecting theme color for "List Item" is when it gets defined entirely as LISTROW button. That's in File Select editor now.
In the uiTemplateList() code however, the button gets a NULL icon, and a "" string. This then gets added as LABEL type later.
I wonder if the itemL() function could somehow find out it's a member of a list via layout? Python defined lists then would go OK too;.%%%
%%%Proposed patch: http://www.pasteall.org/43485
See also mail http://lists.blender.org/pipermail/bf-committers/2013-June/040970.html%%%
%%%That's quite a few hacks, wouldn't adding a LISTLABEL type make the code cleaner?%%%
%%%Yes… but it would mean the need to expose it to python (through RNA ui api , probably as an option to layout.label), and the need for all python uiList classes to use it instead of usual label… not straight forward for addons programmers. While current solution is hackish, but fully under the hood (i.e. end UI api user has nothing to do).
So I’d say it’s a trade-off, between something not-that-nice but which does not need any changes to actual UI code, and something cleaner but modifying the UI API (in a somewhat strange way, "use this option only inside list item draw functions").%%%
%%%This is "only" a UI theme color bug, rather not introduce too many hacks for that.%%%
%%%Ah, I wasn't suggesting to expose this to python, just to change the type of the labels inside the list automatically to a LISTLABEL (either changing but->type afterwards or doing it in uiItemL if a list is being created).%%%
%%%Ah, ok, yes, that would avoid abusing UI_BUT_COLOR_LOCK at least… Working on it.%%%
%%%Updated patch: http://www.pasteall.org/43496/diff
Compared to previous one, had to edit handler code too to take into account new button type.
Note I completely removed widget_state_label(), it actually does nothing more than widget_state (i.e. use text colors from default color set), afaict.%%%
%%%Could the same code be used to display those things? Could someone can explain this case?%%%
%%%Bastien: patch looks good to me know. Only thing I would change still is to replace the do / while loop with a simple for loop. Probably it works fine the way this function is called here but no need to introduce the risk of a NULL pointer access for the first item.
Czarek, I don't understand the question? This code is a fix for the bug so that it uses the theme colors for list items, it will be committed to the Blender code soon.%%%
%%%Brecht, never mind i will read the code.
By the way i found another:
option ui elements in F6 after operator box use 3d view "Theme space Settings Text Highlight" color
attaching image%%%
%%%Fixed in r57760, thanks for the report.
@ Czarek: Please open a new bug report, easier to track this way…%%%
