render cycles preview + modify matrial #35896
Reference: blender/blender#35896
%%%about: crash blender
when: I change a material at the same time there is a render cycles in preview window.
This is the same as the bug [# 34725]
Also tested with blender 2.67 and 2.66a
windows error report :
Signature du problème :
Drivers Radeon 13.6 - 13.101-130604a-158071E-ATI (I has tested with 13.4)
OPEN GL : 6.14.10.12337
%%%Can confirm the crash. (Win 7 x64, SVN 57844).
Just start the viewport render (attached file) and change the Strength value of the Emission shader inside the Properties editor. %%%
%%%Fix in svn now, thanks for the report.%%%
%%%(translate google)
Thank you for your reply.
Your message appears to indicate that you have found a solution.
But I do not understand what I do. So I downloaded this:
http://graphicall.org/?keywords=57844
I started this program r57844 blender, and had exactly the same error.
Blender to the left I hereby amended texture of an object at the same time that "render cycles" worked.
Is this normal?
thank you
FR texte :
Merci pour votre réponse.
Votre message semble indiqué que vous avez trouvé une solution.
Mais je ne comprends pas ce que je dois faire. J'ai donc téléchargé ceci :
J'ai lancé ce programme r57844 blender, et ai eu exactement la même erreur.
Blender à quitté des que j'ai modifé une texture d'un objet en même temps que "render cycles" fonctionnait.
Est ce normal ?
Merci%%%
%%%I should have mentioned, the fix is in revision 57846 or newer. There should be new builds with the fix here soon:
http://builder.blender.org/download/%%%
%%%Hello,
I went recovered the 57874 version and it works perfectly. Thank you for all the work you do. I'm going to take my training to this software. Good day to you all.
Friendly.%%%
