bridge edge loops joining vertecies that are far away #36211
2 Participants
Reference: blender/blender#36211
all
2.68 release
using bridge edge loops on the attached blend-file doesn't connect the nearest vertices of each edge loops on the right peak.
%%%Checked the report, this is a bit of a corner case, it could be made to work well but this is also a limit with the current method the bridge tool uses.%%%
%%%Hi Campbell,
Thanks for the confirmation. In our typical use case at our Highscool, our students are having this nearly every time. So for us it's more of a normal than corner case. The current workaround is to export to Sketchup and then reimport the triangulated mesh back, which is not optimal.%%%
%%%I should mention, in this case Scanfill mesh->faces->fill, (alt+f).
works better since one loop is inside the other.
%%%fixed r60210.%%%
%%%Thanks a lot Campbell.%%%
A Regression happened here, the attached file edgeloops are briged well in 2.69 but not in 2.70/latest SVN anymore.
@bliblubli, tested, works fine
5d63f162d5
, (also we're not on svn anymore).can you show an image of how it fails?
@ideasman42 I meant GIT, but too used to say SVN ^^. Just tested on Linux, works for me too, weird. Still on Windows 7 64bit, it didn't, but I've no access to Windows ATM. I'll try to test it further tomorrow.
After several test on different machines, all work with latest buildbot. After a clean install, my version worked again too, don't know what happened. Please excuse me for the wrong report.
Kind regards
