Inconsistent curve fill behaviour #36384
Reference: blender/blender#36384
Windows XP/ Windows 7 64Bits
Long standing bug at least since 2.5
Curve fill is inconsistent and behavior could be improved:
2D Curve always has fill on when extrude is zero
3D Curve never has fill even though blender is apparently fully capable of calculating the fill
(See attached files)
*A 3D curve as no fill as seen on the green object even if fill option is set to full, even though blender is fully capable of calculating the fill of a non planar curves (as seen on blue and yellow objects)
*Yellow object (imported to Blender from Inkscape with the SVG import script) as a "3D" vertex with Z coordinate different than local zero even though it is a 2D curve (again showing that Blender is fully capable of calculating fill on non planar curves)
Suggestion/feature request #1 : If possible, while fixing these bugs (if they are indeed bugs) I would rather have blender allow filling 3D curves then disabling the option. I know this may lead to undesirable or uncontrolled triangulation of the resulting surfaces but this should be up to the user, and I find this better than not having that option at all, as this sometimes proves useful in certain situations.
Suggestion/feature request #2 : Would it be possible for Blender to keep the Z coordinates of curve's vertex saved even if the curve is set to 2D; so that when reverting to 3D the Z positions could be restored easily (Flatening could still be easily achievable by scaling to zero in Z axis.).%%%
%%%I don't understand this report:
%%%Sorry about the confusion, must have missed a file save before uploading the attachment.
Improved the reported file, I'll try to explain as simply and as clearly as possible, and it goes as follows:
*Yellow "SVG Import" object - 2D Curve with a "3D" vertex > Should not allow vertex with local Z different then zero
*Red " "Bezier Red" object - 2D curve with fill set to "None" > Fill is visible, should not have fill present
*Blue "Bezier Blue" object - 2D curve with non planar fill > It's correct! Shows blender can correctly calculate it
*Green "Bezier Green" object - 3D Curve with fill set to "Both" > Should show a fill, but has no visible one
Basically 2D Curve with extrude zero always as fill
3D curve never has fill
%%%Could not upload new file, so here it is http://www.pasteall.org/blend/23287%%%
%%%Ok, new file I understand, this looks like a bug. Assigning to Sergey.%%%
%%%Couple of comments:
So after all, bug is only happens with yellow object. Other cases i would not consider a bug and also would rather move them to TODO. Trying to make things more clear there would open the can of worms with backwards compatibility and so,%%%
%%%(Sorry for the delay responding, on vacations with bad connectivity here)
Yeah I guess I must have misunderstood what all those settings mean then, maybe something to be clarified for blender 2.7 where backwards compatibility is less of a concern. Still cap fill for non planar beziers would be very useful, especially if it benefits from bmesh, hoping we don't loose that.
Also, nothing wrong with blue spline, just trying to prove my case, showing a non planar fill.
About yellow spline happens every time I use SVG importer. To recreate just simply import any drawing from an svg file (I create mine in Inkscape) and splines are imported as 2D by default, but all of them allow vertex to be displaced in Z until I press 3D and then 2D again; then it is no longer allowed and bug no longer manifests. My guess is there's some sort of bug with the importer.%%%
%%%That as a bug in python API. Fixed now in svn rev59152.
As for other issues reported here, it's more up to making things more clear from communication POV. We're actually avare of the crapyness but didn't find better solution for now which wouldn't break existing files. Wouldn't consider this a bug, it's more up to 2.7 where we might break some compatibility.
But if you could think of more clear wording or interface for existing state of art, this kind of feedback would be really appreciated :)%%%
%%%Thanks, you guys are the best.
I'll study the case to see if I completely understood what all settings mean, and then try to think of a new way to expose the functionality without breaking anything and being the least invasive possible.
If I come up with something decent I'll report here. Thanks again :)%%%
%%%Hello again, ok so here what I've come up with. If I understood it correctly these fill settings concern mostly the bevel option, so in an attempt to keep things simple and not break backwards compatibility I would propose just simply renaming the options to be more consistent and avoid future misunderstandings, and if possible perhaps changing the place in the UI where the settings are accessible.
So instead of "Fill" which seems to vague and confusing I would name it something along the lines of "Bevel Placement", "Bevel Options", "Bevel type" or "Bevel Shape" since from that POV the available options will make more sense and be more easy to understand.
Then inside the dropdown menu we currently have two different set of options, one for 2D and another for 3D curves which in the end seem to achieve the same end results, so I would propose unifying them:
Also if necessary these options could be placed next to the "Bevel Depth" box under the "Geometry" panel, that way they would probably be more in context with what they affect.
What do you think about these changes, better or worse?%%%
