User Preferences "Addons" panel bogs down the whole interface #36387
8 Participants
Reference: blender/blender#36387
Win7, Quadro 4000/Geforce GTX 680
2.68.1 r58588
The "Addons" panel in the "User Preferences" window seems to read the entire script library on every GHOST event happening in that panel. Just moving the mouse from one element to another, e.g. mouse over background -> mouse over search panel, triggers blender to reread all scripts.
I tested this with ProcessMonitor and the attached config.
This behavior is especially bad with blender installed on a global network drive.
%%%also confirmed in Ubuntu with: strace -e trace=file blender%%%
%%%Confirmed. The userpref Addons panel runs the addon_utils.modules() function on every draw (space_userpref.py, USERPREF_PT_addons.draw, line 1145). The actual module loading happens only once (unless file times changed), but it still has to call os.listdir to test all the file names, paths and dates (in bpy.path.module_names()).
It seems to me this happens by design to make sure the modules list always reflects actual files. Caching these file lists properly would require some way of detecting file system events and set a dirty flag at least, not sure if that is feasible.
Campbell: What do you think? Any nice way to avoid slow file access on the user side?%%%
%%%Seems related to this report:
https://projects.blender.org/tracker/index.php?func=detail&aid=35961&group_id=9&atid=498
I couldn't exactly redo that issue but if it's doing file access on every draw, then it makes sense, because I have an SSD drive where you probably wouldn't notice it much.%%%
%%%Thanks Lukas and Brecht for looking into this issue.
It seem to me that an update on every event in that panel is a little bit overkill. We have blender installed on a global network share to ensure that all machines on the network have the same version available when updating. That works pretty well except with this issue. When the panel is open, blender freezes for 2-3 seconds every time an update event happens - and you can barely move your mouse there without triggering some kind of event. :)
Couldn't that list only be loaded once when opening the user preferences window or after switching to the addons panel or maybe with a Reload/Refresh button? How often are addons expected to change and is it really necessary to constantly check?
The report linked by Brecht is exactly what we are experiencing, except it is not a regression from 2.67 on our side. As far as I can remember, this issue exists since the beginning of the addon system.%%%
%%%Regarding filesystem reads, I knew when writing this that reading on draw could be an issue, but even on a non-ssd this goes fast for me (I expect the OS cache kicks in).
Note that its not actually reading the data on draw, just getting a list of files in a directory, the module info is read and cached.
Of for whatever reason its reading from the physical disk on every draw - that will be a problem of course.%%%
%%%Here's my method of producing the error, is quite alternative.
%%%const, I think you accidentally replied to the wrong bug report?%%%
%%%I'd like to add that I've also had trouble running Blender from a network drive due to the fact that the addons preferences window grinds to a halt. This is even on a very, very fast local network. I've had this experience since starting at my school two years ago. It gets worse the more addons you have in the install directory.
Win7 Pro x64, probably remotely accessing Win Server 2008 R2, but I'm not positive. I don't have access to all of that, just my home folder.%%%
%%%@Campbell, Brecht: Would it be acceptable to cache the addon files list once, e.g. when opening userprefs or even just when starting Blender? The userprefs ui could get an explicit refresh button, or the addon list could just be reloaded along with F8 script reload (not sure if that makes sense). The file space works this way after all ...%%%
%%%@Lukas-132 Toenne, caching the file list needs to be done with care - since you can install addons once blender is loaded... change the user preferences for the script path.
Its also possible to load blender, then restore factory settings from a previous install - which would change the addon paths...
So... best to do,
%%%eh, make that
restore FACTORY settings
-->restore settings
%%%%%%On my system the addon viewer in User Prefs is responsive. I can imagine it's not very fast for everyone, but things work 'as meant to' , how the buttons in blender work anyway.
I suggest to mark this as a todo in wiki for later investigation? Especially if a proper fix isn't trivial or about to happen soon.%%%
%%%@Ton, issue is that filesystem list isnt always cached (network drives), blender should be usable on a network drive.
Since this isnt a regression its not so bad but Ill try find time to check on this next week.%%%
%%%I've added a patch as suggested:
https://codereview.appspot.com/13271043/
There may be missing cases where the "scan_addons" flag should be set in the RNA. Also not sure if UserPrefs is the right place for that flag, but seems to be the most intuitive solution.%%%
%%%Your reported issue has been fixed in SVN. Thanks for taking the
time to report!.%%%
