UI slows down while nodes are being calculated #36393
2 Participants
Reference: blender/blender#36393
Duplicates: #36239
Fedora 18, 64 bit, Nvidia GTX 460, proprietary drivers.
2.68a, and git show the bug.
While nodes are being calculated, if there is either the backdrop or an UV/Image Editor area is showing a viewer node, the ui gets unresponsive and stutters.
This gets even worse if a scopes panel is visible in the Image Editor.
Open the attached blendfile, change the current frame and then drag some nodes around while blender is calculating.
%%%Browser crashed while uploading, hopefully the blend gets attached now.%%%
%%%I don't get a noticeable slowdown with the basic ui setup in that file, but showing histogram in the image editor clearly shows blocking ui. gprof confirms that a lot of time is spent on scopes_update(), which calculates the scopes data after each image update:
http://www.pasteall.org/44686
Disabling the actual calculation in scopes_update() removes the ui blocking. So, unless we want to move scope updates into an independent non-blocking job, we should probably avoid these very frequent updates. The scopes get tagged dirty all the time during compositor jobs via the ND_COMPO_RESULT notifier -> image_listener callback. The notifiers get set both by a 0.1 second timer as well as on job update, i.e. when the compositor updates its progress.%%%
%%%Same issue with Cycles reported in 36239%%%
%%%The problem here is that the scopes updating is slow and it gets repeated frequently during render/compositing. Proper solution would involve making scopes updates an independent threaded job, but that's more of a ToDo than a simple bugfix. Added to our list, for now you'll just have to accept it or close the scopes panel during render/composite, sorry.%%%
%%%Okay, so the problem with the scopes is a known Issue.
For some reason, I also get a slowdown with the basic setup of the file, so without scopes. It seems to me that this is an other Bug, unrelated to the scopes.
Can anyone else reproduce this? Because Lukas can't, I have also tried this on a fresh system and blender build + blender 2.68a release Version to get sure it is not related to some configuration Issues. but still get slowdowns. A video showing the effect is attached now.%%%
%%%Have you tried "Load Factory Settings" (File menu)? It might be some threads setting ... Can you give us more detailed system info (Help->System Info)%%%
%%%I have attached the system Info and figured out, that the slowdown is caused by the Images Draw Method being set to GLSL. If it is set to 2D Texture or Pixel Draw, the stuttering is greatly reduced.%%%
