Freestyle: Line thickness modifier with certain blend types incorrectly calculated #36599
2 Participants
Reference: blender/blender#36599
Ubuntu 13.04 amd64 + GeForce GTX 670
Tested 2.67b and r59609
When using line thickness Modifier with Blend = "Multiply" and Value Min = Value Max = 1.0, the modifier should not affect the line thickness, but I get strange results that the outlines are 1/2 time as thick as I expect. The line thickness seems incorrectly divided by 2.
Similarly, if blend type is "Divide", the line thickness is incorrectly multiplied by 2 so the render result shows unintended thick outlines.
Also, it seems that the blend types "Minimum" and "Maximum" take no effect.
(I'm not sure if the other modifiers such as line alpha modifier have the similar problems.)
%%%Fix committed in the trunk revision 59652. Thanks a lot for pointing out the bugs!
I think only the bug with the Minimum and Maximum blend types affects alpha transparency modifiers.
The bug in thickness modifiers was in the treatment of inner/outer thickness values and not related to color/alpha modifiers.%%%
%%%Thanks, it works properly now!
However the fix broke backward compatibility, so I have to modify my older .blend files which use the thickness modifier...
