Second character motion actuator overwirte forward motion [patch] #36703
5 Participants
Reference: blender/blender#36703
%%%This bug report is related to [#36329] Character physics type doesn't react to actuator?.
I know that I can enable the "Add" button to get it work. But if add is enabled and you move and rotate the rotation speed does not match with the character rotation.
I made a fix for that. I also fixed the double jump problem. Now it is possible to jump permanently and make a double jump. I also removed the now unnecessary "Add" button.
#40682 was marked as duplicate of this issue
%%%Is this a new bug, or just a patch for an existing bug?%%%
%%%I haven't actually tested the patch, but I do see some issues with it. First off, the add button is to allow two motion actuator bricks to add movement (not just movement and rotation). For example, if I have four actuators that control 4 directions, I can combine two of those to get diagonals. It looks like your patch removes the ability to do this. Also, the motion actuator shouldn't be doing OnGround checks, this should be the responsibility of the character physics.
I've also refactored the physics code so (among other things) the motion actuator receives a character controller reference and doesn't need to keep doing nonsense with the generic physics controller. However, that's not really a problem with your patch; I'm just noting a future conflict.%%%
%%%@daniel-34 Strokes.
It is just a patch for the existing bug.
@Mitchell Strokes.
You are right. Diagonal movement is not possible, like the other motion actuator. I am also not satisfied with OnGround check in the motion actuator.
If I have time I try to find a better solution.%%%
%%%Moved from Game Engine to Patches%%%
%%%I uploaded a new patch. Now diagonal movement and rotation is possible.
The problem why the add button not working with rotated objects was, that GetWalkDirection() returns returns the rotated movement vector.
There are only two ways to fix that .
I choose the the number two because it need less calculations.
About the double jump fix. I think there are no much better way to fix that. Because I need to know when the keyboard key is released. This information I only can get from the motion actuator.
I can make noJump() or keyStatus(true) method or modify the Jump(true) method to pass this information through to the character physics. But this will need the same changes as passing the onGround() to the motion actuator.
I am also not sure which class(es) you mean by character physics and generic physics controller.
I added the "Add" button back. But I think this button is unnecessary. Add can be always on. There are only two things for that it is good for.
If you don't want to move diagonally or stop with a 0,0,0 actuator. But this can be also done with the logic controllers (XOR, AND) or just by releasing the key.
Added subscriber: @dr.sybren
How safe is such a static variable when there are multiple actuators?
Normally it is save to use static variables. But what I missed to test if we add more then one Character object.
For the actual patch D1206 it is not necessary any more. It get the actual rotation and velocity directly from the object.
This issue was referenced by
29e968a315
Closed by commit
29e968a315
.Added subscribers: @JosephMasaki, @brita, @sreich
