EXR Layers are not fully updated on scene load or image refresh #36755
Reference: blender/blender#36755
OS X 10.8.5
r600158
Scenario: You have an existing multilayer EXR loaded in the compositor. For one reason or another, the number of layers in this file is changed (probably because a pass was enabled or disabled when the file was re-rendered). When simply reloading the .blend file or hitting "refresh" on the image datablock, the layer list will not update. It will still show the layers as they were when the file was first loaded. This no longer corresponds to what is actually in the file, so passes no longer correspond to their correct datasets. You get things like the "mist" pass reading data from the "normal" pass layer. To fix this, you need to open the file browser on the image block, and select the EXR again to force a layer list update.
%%%How are you refreshing the file? There is no reload button in the node, which perhaps should be added. Reload in the image editor seems to work here.
Probably it should not do this refresh automatically, only on a user action. Otherwise you can then lose some node links without even knowing it, if the EXR file is incomplete or changed for some reason.%%%
%%%The image node actually does have a reload button. It's not on the node itself, but it appears in the N-panel. (incidentally, that's also true of Cycle's image node).
Primarily I mean loading the file. If you change an EXR then load a .blend that has it in the compositor, that image node will be broken. It will read the data from the file again (since that wasn't in the .blend file) but it will continue using the layer/pass list from when the scene was last saved, which no longer corresponds to the data it's reading. I guess you could argue the alternative is equally bad (the compositor trashing links and outputs when loading a scene).%%%
%%%I guess in essence the issue is that I'd expect reloading a .blend to have the same effect as hitting "reload" on all image blocks at once, but that's not completely true for multilayer EXRs. %%%
%%%Ok, so reload works.
Right now it stores the pass index in the socket, rather than the pass name. Maybe that should be changed, will leave it to compo/nodes experts to decide.%%%
%%%The issue here is that the image node does not simply display the image layers, like e.g. the layer selector in image editor does. It creates persistent sockets, which must be updated when the image layers change. This happens on image reload, but not right after loading a node (BKE_image_signal). There are probably comparable situations not related to the image node where a problem like this can occur, e.g. when removing images from a sequence (iirc image user structs store persistent image info too).
Nodes have the concept of "verification", but it's not very well defined atm and only used in a few special cases, like static socket templates changing between Blender versions or node groups updating. Cleaning up this procedure and making it work for image nodes might help.
%%%To me the problem isn't really that the sockets aren't added/removed, in my opinion that's something that can be left to the user to do manually, to avoid surprises. It may seem convenient, but as a general rule I think if you open a .blend, make a change in some unrelated area and then save it, there should be no changes. That's especially important if you work in a team, you want to be able to edit a part of a .blend file without of fear of breaking other stuff.
To me it's just strange that there is a pass index rather than a pass name. If it did a lookup by name, you might have too few or too many output sockets, but at least it would give you the right pass matching the socket name.%%%
%%%@brecht: True, names instead of indices would probably help a lot (although this would in turn break if you rename a EXR pass, not terribly bad i guess). I'll look into it, just have to be a bit careful with this node, it can be really nasty in terms of backward/forward compatibility.%%%
%%%Fixed as suggested in r60234. EXR passes are now matched by name in the compositor, so you get the correct outputs in the file node for the passes that still exist.%%%
