Game Engine's "Use Frame Rate" Doesn't go >60fps. #36756
Reference: blender/blender#36756
Category: Rendering
Windows 7 Pro, 64-bit, Radeon 7750
Blender 2.68a (64-bit, official build r58537)
I can't get the Blender game engine to lock to 144fps on my 144Hz monitor, an Asus VG248QE. Regardless of what my monitor's rate is set to, having "Use Frame Rate" in the System options checked always results in 60fps. Adjusting the rates in the full screen options, or other options doesn't seem to work around this. I can turn off the "Use Frame Rate," but then things run a bit too fast.
1: Launch Blender on a monitor with a refresh rate set to >60 fps.
2: Change the render engine to "Blender Game"
3: Turn on "Frame Rate and Profile" in the Display options. "Use Frame Rate" is already on by default.
4: Press P to start the game engine.
Result: The game engine always runs at 60fps, even when the monitor is on 85, 120, of 144 Hz.
%%%Wrong section, sorry.%%%
%%%Moved from Blender 2.6 Bug Tracker to Game Engine%%%
%%%There's an fps settings under world tab > physics panel, did you try changing that? Seems that affects more than just physics.
I don't know the specifics of how these settings are supposed to work though, will leave that to a game engine developer.%%%
%%%Brecht, changing that setting did exactly what I needed to do.
It turns out that the physics fps setting is what the "Use Frame Rate" parameter is looking at, not the screen's refresh rate. Setting the physics fps to 200 caps the frame rate at 200, even though that rate isn't displayed.
Maybe the tooltip on the "use frame rate" checkbox should reflect this.%%%
%%%If you want to cap your framerate to the screen's refresh rate, you can enable Vsync, which is in System panel of the Render properties. However, a tooltip change should probably be done to make Use Frame Rate clearer.%%%
This issue was referenced by blender/blender-addons-contrib@55e3be560e
55e3be560e
Closed by commit
55e3be560e
