Vertex coloring in preview window meshes default to black, makes preview useless #36757
Reference: blender/blender#36757
%%%This using Windows 7 Home Premium with an Ivy Bridge i7, an ATI card, and 16 Gigs of RAM
To find it, just open the .blend file and look at the preview.
The point here, if you use a vertex color channel to directly effect the color of the shader, you end up finding that either the meshes in the preview window do not have a proper Vcol channel at all or they do have vertex colors, but they are black by default (and what I mean is the window built into the material context panels).
What this means is the fact that if you're using vertex colors to drive the color of the shader (through the use of the color output of the 'attribute' node), than the preview window mesh will turn black and in turn make the preview window useless.
Now this is just an issue with the preview window meshes and not Cycles itself, because the shader in the rendered view and the F12 render works like it should.
Actually, I wonder if in the future, we start adding some interactive settings to the preview window so as to improve the ability to overview everything before we do the final render (like the window meshes automatically getting more vertex color channels as they are added which you can change the color of to test colors and mixes), but if you can fix the initial issue to where the preview window is at least usable with vertex colors as color information, that would be good.
Thanks.%%%
%%%Also, I forgot to mention this, but I don't think vertex colors as shader color information ever worked with the preview window meshes in any version of Blender, I tested this using one of the latest VC11 buildbot builds, but to my knowledge, this has been a preview mesh issue ever since they were introduced.%%%
%%%Fix on rev. r60206, thanks for reporting.
" Adding 'Col' vertex color layer to preview cycles meshes
The material can be used by more than one mesh, thus we can't read the real object vcol. At least not for now.
I think it's a matter of workflow. But since the preview objects have an UV layer it should be fine to have Vcol too.
@brecht, if you think otherwise, please roll back the commit.%%%
%%%The fix is fine with me, thanks. A preview render can only do so much, if you do more complex setups then viewport renders become a better option.%%%
