OSL clamp, min and max functions have wrong signature when arguments are integers #36863
2 Participants
Reference: blender/blender#36863
w7 64bit full sysinfo in attached .blend
version 2.68 (sub 5), revision b'60058M'. b'Release' build date: b'2013-09-11', b'19:17:36'
all older versions seem to behave identical
The clamp(), min() and max() functions should return the same type as the types of their arguments (says the docs :-). For int arguments this appears not to be the case: the return type is float. This means that if we have to cast the return value back again to an int if we want to pass it to a function taking an int argument. Please see the attached .blend with the shader code and it is probably much clearer than what i try to describe here :-)
The workaround is obvious of course, but maybe this can be passed upstream.
Uncomment the indicated linen in the attached .blend and (re)compile the shader: the compiler complain it cannot find a matching f(float) function (because there is only a f(int) defined.
%%%The issue can even be reduced to a single line of code:
int a = clamp(1,2,3);
gives error: Can't assign 'float' to int a%%%
%%%Thanks for the report, fixed in SVN 60427.
The bug was fixed in OSL 1.3.2 already, but we used an outdated version of the stdosl.h file.%%%
