iterator.increment crashes in try/except block when it can't increment any further #37092
Reference: blender/blender#37092
%%%-- System information --
Windows 7 64 bits
revision 60773 and 2.68 official release.
error in revision 60773 and 2.68 official release.
I don't think it ever worked.
When an iterator is at its end (which means iterator.is_end == True) and is incremented again in an try/except clause, the RuntimeError this causes seems to be improperly handled. Referencing the object after the the except clause, that contains a return statement, so the remainder of the code shouldn't be executed, causes a crash.
try to render an image in the attached blend file.
more generically, increment an iterator that is pointing to its final object in a try block, and refference it after the except clause, which contains a return statement.
%%%The problem seems to be more generic; it also crashes when using an if/else clause. I attachted another .py file that uses an if/else clause and causes a crash.
%%%updated file:
http://www.pasteall.org/46558/python%%%
%%%Tamito, can you please check on this issue? Thanks!%%%
%%%Thanks a lot for the bug report. Fix committed in trunk revision 61233. Further test would be much appreciated.%%%
%%%Closing then (easy to reopen if need arises). :)%%%
