Inconsistent numeric input conversion #37327
2 Participants
Reference: blender/blender#37327
Win7/64, AMD HD 6850 (driver 13.9)
Blender 2.69.
Same problem in oldest 2.5 release
Entering the same numeric value in a numeric edit box does not always lead to the same value being stored.
Details:
Binary format (little endian) of decimal value 0.0001
A blend file is not attached because you have to perform the steps to see the behavior.
Problem confirmed here:
http://blenderartists.org/forum/showthread.php?316672-Entering-numeric-values%%%
%%%Will try to understand what happens here.%%%
%%%In fact, we do have a float error issue here, but the real problem was that the "µm" unit text wasn't drawing (instead of expected 0.1mm, you should have get 99.89738µm)…
Fixed in r61198, thanks for the report. :)%%%
%%%Thanks for the quick reply and fix. I'll check it out as soon as the built is available.
However, sorry for disagreeing, but this does not target the actual problem. Even a single precision value is capable of storing 0.0001 more precisly than as 0.00009989738. The closest values (including irrelevant decimal digits) are:
0.0000999999974737875
0.0001000000047497450
Of course, both displayed as 0.0001 as irrelevant digits are truncated during formatting.
Single precision is capable of distinguishing between 0.00009989738, 0.00009989739, ......, 0.00010000000, 0.00010000001, so there is no reason to "round" to 0.00009989738. This is even a large deviation.
Please also note that, as I've just figured out, the problem is even unrelated to the conversion from/to metric system. You can prove it this way:
Procedure #1:
Procedure #2:
This does not make sense. At the point in time when switching to metric, the previous values (zero or three) must not have an influence on what is stored and displayed now. Consequently the error is when parsing/storing a new input. In any case, the old value must just be overwritten and have no influence on the new value.
Anyway....
I'm not familiar with the source code, so it took a couple of hours to find the right location where the magic happens. In short: The problem is that we actually edit a median point, not a single vertex position. When editting is done, the difference between the old and the new median value is added to the previous value. That's not really surprising, but by becoming aware of it after looking at the source, it explains the problem. Long story short:
New value = OldValue + Difference = 3.0f - (0.0001F - 3.0f) = 0.0009989738F
This is because the difference is not exactly -2.9999 but -2.99990010261...
This computation using the differences makes sense when more than one vertex is selected, but it causes unneccessary inaccurarcy whenever only one vertex is selected. Then just storing the new value would be appropriate. Another option, when the new entry is accepted, is converting all involved values to double before the computation and convert the final result to float. Of course it will never be exactly 0.00001 but as close as possible.%%%
%%%...Or, in blender units, first enter 9999, then enter 0.1. Result is 0.09961. Considering that 0.1 is not an extremely small value, the result is not acceptable (IMO).
Then enter 0.1 again and you'll get 0.1 only because the difference to the previous value is not so big.
%%%Thanks for investigating this, Armin. Committed an (obviously partial) fix in r61208. Ultimately we should probably switch to doubles, but I think there are more parts of Blender that would need that too, so that’s more like a TODO topic. ;)%%%
%%%Just tested in the latest build. It works. :) Thanks for the quick fix!
I have another closely related issue, but I'm still pondering whether or not to report it is as a (seperate) bug/inconsistency. Don't want to create unnecessary noise.%%%
