Cache Relative wrong path issue on Copy-Paste objects #37471
Closed
opened 2013-11-15 13:28:04 +01:00 by Daniel Martinez Lara · 6 comments
{F27532}System Information
Ubuntu
Versión 12.04 (precise) de 64-bit
Núcleo Linux 3.8.0-33-generic
GNOME 3.4.2
Mermory: 7,8 GiB
Processor: Intel® Core™ i7-3770 CPU @ 3.40GHz × 8
renderer: 'GeForce GTX 650 Ti/PCIe/SSE2'
vendor: 'NVIDIA Corporation'
version: '4.2.0 NVIDIA 304.88'
version 2.69 (sub 2), revision b'61181'. b'Release'
build date: b'2013-11-07', b'02:02:33'
platform: b'Linux:64bit'
After coping an object having a Mesh_Cache modifier, the message of "Copy to z-buffer" shows, when you paste the object to other scene or file the path into the Mesh_Modifier changes adding some "../" at the beggining of the original file, making the object lost the Cache.
I had include a Zip file whith a screencapture and the files used to reproduce the issue.
  • Create a new blend file
  • Animate an object
  • Select the object
  • Export animation as MDD
  • Create other new file with the same (new) object than previous file
  • Add the mesh_cache modifier and link to the exported cache
  • Save the file, just to be sure all will be at the same path
  • Create a new empty Blend file and save it
  • Copy the object with the mesh_cache modifier from the previous saved file to the empty file
  • Go to modifier section of the object and you will find it losses the correct path to the cache, although the directory structure is at the same levels
Best regards
{[F27532](https://archive.blender.org/developer/F27532/blender_cache_test.zip)}**System Information** Ubuntu Versión 12.04 (precise) de 64-bit Núcleo Linux 3.8.0-33-generic GNOME 3.4.2 Mermory: 7,8 GiB Processor: Intel® Core™ i7-3770 CPU @ 3.40GHz × 8 renderer: 'GeForce GTX 650 Ti/PCIe/SSE2' vendor: 'NVIDIA Corporation' version: '4.2.0 NVIDIA 304.88' **Blender Version** version 2.69 (sub 2), revision b'61181'. b'Release' build date: b'2013-11-07', b'02:02:33' platform: b'Linux:64bit' **Short description of error** After coping an object having a Mesh_Cache modifier, the message of "Copy to z-buffer" shows, when you paste the object to other scene or file the path into the Mesh_Modifier changes adding some "../" at the beggining of the original file, making the object lost the Cache. I had include a Zip file whith a screencapture and the files used to reproduce the issue. **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps - Create a new blend file - Animate an object - Select the object - Export animation as MDD - Create other new file with the same (new) object than previous file - Add the mesh_cache modifier and link to the exported cache - Save the file, just to be sure all will be at the same path - Create a new empty Blend file and save it - Copy the object with the mesh_cache modifier from the previous saved file to the empty file - Go to modifier section of the object and you will find it losses the correct path to the cache, although the directory structure is at the same levels Best regards
Author
Member
Author
Member
Added subscriber: @pepe-school-land
This issue was referenced by blender/blender-addons-contrib@d4284056c7
This issue was referenced by blender/blender-addons-contrib@d4284056c7b3d512ba3e54bee16c83530c63e2bb
This issue was referenced by d4284056c7
This issue was referenced by d4284056c7b3d512ba3e54bee16c83530c63e2bb
Closed by commit d4284056c7.
Reference: blender/blender#37471
