Wrong OpenGL Render Preview (objects not visible in the final rendering are shown) #37951
Closed
opened 2013-12-26 12:55:00 +01:00 by Robert · 5 comments
LinuxMint 15 x86-64
Kernel 3.8.0-30-generic
NVidia GTX 760
Broken: Blender 2.96 r60991
OpenGL Preview and "Only Render" Display settings show objects not visible in the final rendering{F56836}
  • open the attached *.blend file
  • in the "Only Render" Viewport preview, both, the cube and the sphere are visible
  • when you click on the opengl preview also both, the cube and the sphere are visible
  • but when rendering the scene using cycles or the original blender renderer, only the sphere is visible
Steps I've made to create the attached blender file:
  • open blender
  • load factory settings
  • create new mesh-object (sphere)
  • add the sphere to a new group (I've used the properties panel) and name it "A"
  • move the sphere (I've moved it using - [x],- [x],- [x],[enter])
  • move the sphere to another layer
  • select the cube
  • in it's duplication panel, select group and then the group "A"
  • select cylces render
  • open the viewport properties (using - [x]) and check "Only Render" => the cube and the sphere are both visible
  • render it in cycles => only the sphere is visible
  • render it using the blender render => only the sphere is visible
**System Information** LinuxMint 15 x86-64 Kernel 3.8.0-30-generic NVidia GTX 760 **Blender Version** Broken: Blender 2.96 r60991 **Short description of error** OpenGL Preview and "Only Render" Display settings show objects not visible in the final rendering{[F56836](https://archive.blender.org/developer/F56836/repro-scene.blend)} **Exact steps for others to reproduce the error** - open the attached *.blend file - in the "Only Render" Viewport preview, both, the cube and the sphere are visible - when you click on the opengl preview also both, the cube and the sphere are visible - but when rendering the scene using cycles or the original blender renderer, only the sphere is visible *Steps I've made to create the attached blender file:* - open blender - load factory settings - create new mesh-object (sphere) - add the sphere to a new group (I've used the properties panel) and name it "A" - move the sphere (I've moved it using - [x],- [x],- [x],[enter]) - move the sphere to another layer - select the cube - in it's duplication panel, select group and then the group "A" - select cylces render - open the viewport properties (using - [x]) and check "Only Render" => the cube and the sphere are both visible - render it in cycles => only the sphere is visible - render it using the blender render => only the sphere is visible
Author
Author
Added subscriber: @Robert42
Sergey Sharybin self-assigned this 2013-12-27 10:15:14 +01:00
Added subscriber: @brecht
Discussed the fix with @brecht. It is rather tricky change which is not as straightforward as it first looked like. It is now in our TODO list: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Editors#3D_View
Thanks for the report, but closing it as TODO.
Discussed the fix with @brecht. It is rather tricky change which is not as straightforward as it first looked like. It is now in our TODO list: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Editors#3D_View Thanks for the report, but closing it as TODO.
2 Participants
Reference: blender/blender#37951
