Fix for freestyle iterators with for loops #38213
Closed
opened 2014-01-14 17:34:58 +01:00 by Folkert de Vries · 8 comments
Hello,
As I mentioned some time ago there is a problem with using freestyle iterators in for loops. briefly the problem is that the object returned by next(it), which is implicitly called by a for loop, did not match the it.object: the two were out of sync. an example:
it2 = iter(stroke)
for svert in it2:
  - this will currently crash on the final iteration
  - since it2.object then doesn't exist.
    print(it2, svert, it2.object)
To solve this problem, the iterator and the next() method have to be brought back into sync. To achieve this I added an attribute to BPy_StrokeVertexIterator, "at_start", that tells the next() whether to increment. this attribute is false on default, so the first call to next() won't increment the iterator, thus getting the for loop and the iterator back into sync.
I've implemented this for StrokeVertexIterators only for now, to check whether this change is allowed and if there are any possible problems I've overlooked.
one further point: I've changed the reversed attribute to be a bool (instead of int), but it seems this attribute is not used anywhere. removing it would make iternext() quite a bit shorter.
patch:
freestyle_iterator_fix.diff
Hello, As I mentioned some time ago there is a problem with using freestyle iterators in for loops. briefly the problem is that the object returned by next(it), which is implicitly called by a for loop, did not match the it.object: the two were out of sync. an example: ``` it2 = iter(stroke) for svert in it2: ``` - this will currently crash on the final iteration - since it2.object then doesn't exist. ``` print(it2, svert, it2.object) ``` To solve this problem, the iterator and the next() method have to be brought back into sync. To achieve this I added an attribute to BPy_StrokeVertexIterator, "at_start", that tells the next() whether to increment. this attribute is false on default, so the first call to next() won't increment the iterator, thus getting the for loop and the iterator back into sync. I've implemented this for StrokeVertexIterators only for now, to check whether this change is allowed and if there are any possible problems I've overlooked. one further point: I've changed the reversed attribute to be a bool (instead of int), but it seems this attribute is not used anywhere. removing it would make iternext() quite a bit shorter. patch: [freestyle_iterator_fix.diff](https://archive.blender.org/developer/F68315/freestyle_iterator_fix.diff)
Author
Member
Tamito Kajiyama was assigned by Folkert de Vries 2014-01-14 17:34:58 +01:00
Author
Member
Added subscriber: @flokkievids
Author
Member
quick update to the diff: object duplication wasn't correctly handled
new patch:
freestyle_iterator_fix_v2.diff
quick update to the diff: object duplication wasn't correctly handled new patch: [freestyle_iterator_fix_v2.diff](https://archive.blender.org/developer/F68340/freestyle_iterator_fix_v2.diff)
Added subscriber: @mont29
@flokkievids: For patches, creating diff (https://developer.blender.org/differential/diff/create/) is usually a better solution, helps the reviewing process. ;)
Author
Member
@mont29 : thanks, I created [D222](https://developer.blender.org/D222) with an updated version.
@mont29 : thanks, I created [[D222](https://archive.blender.org/developer/D222)](https://developer.blender.org/D222) with an updated version.
I have just pushed the proposed changes in D222 through 5 separate commits a169989, 41d778f, bab88fe, e9e2813, and b58beed.
Many thanks to @flokkievids for the contribution and sustained efforts on code revisions!
I have just pushed the proposed changes in [D222](https://archive.blender.org/developer/D222) through 5 separate commits a169989, 41d778f, bab88fe, e9e2813, and b58beed. Many thanks to @flokkievids for the contribution and sustained efforts on code revisions!
Reference: blender/blender#38213
