Raycast and replaceMesh #38335
5 Participants
Reference: blender/blender#38335
Win 7, Geforce 730m
Broken: 2.67.0
Raycasting on a mesh which has two materials gives wrong materials on wrong faces, when replace mesh is used even once.
It seems to affect only one triangle on a square mesh in the physics view ( triangle mesh?) only.
The same setup i am using works by only removing the connection to the replace mesh actuator.
I use replace mesh to update the phys mesh.
I detect the material on the mesh with python:
rayCast(to, from, distance, property, face, xray, poly)
mat_name = ray[-1].getMaterialName()
The face it hits gives wrong material.
I suggest looking at my post on BA forum:
http://blenderartists.org/forum/showthread.php?322524-Impaling-projectile-and-equipment-parenting&p=2562865&viewfull=1#post2562865
Pictures:
The cones should impale the wood (brown) and ignore the steel(grey).
The last one in particular:
"Splitting the mesh into two planes (top plane wood, bottom plane metal) the script works.
So from this I then joined the split planes using CTRL + J"
And the problematic face changed into the upper one.
Blend:
raycast_replaceMesh_2_(1)_(1).blend
Press space to execute script.
Manually re/dis-connect replace mesh.
In the console i print The material recieved and the objects name.
None of the Cone_Lower duplicates should recieve the Material Wood, but they do....
Hopefully this is the right place, as i got no answer in my thread where to report bugs.
Added subscriber: @vegetablejuicef
I was pointed to a workaround:
triangulating the mesh before manually seems to solve the problem!
Still, i would expect this to work also with square mesh.
Added subscriber: @Ace_Dragon
Some advice, I think it would help if you retested for the issue in one of the latest buildbot builds, there's been so many changes since 2.67 that one wouldn't know for sure if it since has been fixed, taken a different form, or is still there as is.
That's what a lot of other people do and it often leads to their reported issues fixed.
Tested it with: blender-2.69-fd0b104-win64
The problem persists.
No change.
Hopefully this was meant by " latest buildbot builds ", as i have no idea what you suggested for me to do otherwise.
By buildbot, I was meaning this.
http://builder.blender.org/download/
But since I cannot recall changes to the rayCast() function from the release logs, I would have reason to believe the bug will still be there.
Well, what now?
Is it a bug?
Is it being worked on?
I have been messing around with this since first of January.
Kinda wish to get some confirmation whether i am mad or this IS a thing.
Added subscriber: @raco
Bug confirmed with Blender 2.71 hash
80d3eb6
(2014-07-18).This issue was referenced by
6ee0327594
Closed by commit
6ee0327594
8647c7d501
