Custom Keying Set, XYZ to RGB, odd logic #38619
Reference: blender/blender#38619
Windows XP Professional SP2
SiS Mirage 661 Internal
Broken: Blender 2.69, Date: 2014-01-29 12:29, Hash:
ac27a1a
Worked: unknown
In User Preferences > Editing > Keyframing, if 'XYZ to RGB' is enabled..
If you use a custom Keying Set, and disable the option 'XYZ=RGB Colors', the option doesnt work unless you disable the option in User Preferences.
keys.blend
Here I have a cube, ive added a custom keying set 'Keying Set', I Added Location properties to the set.
'Keying Set' is the active keying set, so with the cube selected, when I press I in the 3D view, this should add the location XYZ channels.
User Preferences > Editing > Keyframing: 'XYZ to RGB' is enabled.
Before pressing I, in the Keying Set Panel and the Active Keying Set Panel (Properties > Scene).
Make sure the 'XYZ=RGB Colors' options are disabled, Shift+LMB.
Now insert the keying set keyframes by pressing I in the 3D view.
You will notice in the F-Curve Editor, the F-Curve colors are RGB.
If you disable 'XYZ to RGB' in User Preferences first, then disable the keying set options 'XYZ=RGB Colors' the keying set options work.
Though also note, you only need to enable one of the 3 options, if any are enable, the RGB option overides all.
Im not sure if this is a bug, but it seems like odd logic.
Added subscriber: @koilz
Added subscriber: @JoshuaLeung
Admittedly the way I ended up implementing what-was-intended-to-be-local-overrides-for-these-settings-on-a-per-keyingset-basis turned out to be somewhat braindead.
Ive looked at this a bit more.
I dont think this is a bug, its just, if the User Preferences settings are enabled, they overide the Keying Set settings.
The other way I guess it could work, is if the Keying Set and Active Keying Set settings ignore the User Preferences settings.
Though I think thats a design decision.
As a user I found it odd why the keying set settings were not working.
This also looks like a To Do!?
This issue was referenced by
e0ee74a171
Closed by commit
e0ee74a171
