Knife tool completely non-functional on interior geometry #38623
6 Participants
Reference: blender/blender#38623
Win 7 64 bit, i7 Ivy Bridge CPU, ATI 7xxx GPU, 16 gigs of RAM
Broken: Latest build tested was done at hash
2038eb1
, I don't know if the knife tool ever worked right in this situation.Short description of error
Open the attached .blend file, press 'K' and try to make a cut, any cut. Notice how Blender acts like the knife tool does not exist, as it's completely unable to do so much as draw the cut line after a segment is confirmed (not to mention being unable to actually 'cut' the geometry). It seems to be that any ray-casting the knife tool does to determine cuts is dependent on exposure to the infinite space outside of the scene, ideally though, you'd think this could be based on exposure to the current position of the view itself. The normals have also been calculate to point inward to show it's not at all related to mesh normals.
Already mentioned above.
BrokenKnife.blend
If this can be fixed before 2.70 is released, then I think anyone who does interior modeling work will be very grateful.
Thanks.
Added subscriber: @Ace_Dragon
#38733 was marked as duplicate of this issue
Okay, it seems like there's a little more complexity in this issue than meets the eye, I updated the bug demonstration .blend to reflect this
BrokenKnife2.blend
With the first .blend, you notice that you can just work around by cutting the mesh from the outside, so here, you can press 'K' to try to make cuts anywhere on the selected cube which happens to be a part of the same object. Notice how Blender can't do so much as draw the lines showing where the cut will be. After that, go back into object mode, select the red cube, go into edit mode, and try to cut that one. Notice how the Knife tool starts working again when you use it on that object
Apparently, it appears the Knife tool will not work if the cut surface is completely occluded or blocked from the region outside of the scene by the object it is a part of (which includes cutting from inside the object as opposed to from outside), it's as if the tool is using a raycasting system that sends a ray from outside of the scene, whereas you'd think it should come from the position that you're viewing the scene from instead (that is, when in perspective mode).
Added subscribers: @ideasman42, @Sergey
@ideasman42, please have a look here :)
Added subscriber: @JoshStrawbridge
◀ Merged tasks: #38733.
This issue was referenced by blender/blender-addons-contrib@cd9aed7059
cd9aed7059
Closed by commit
cd9aed7059
