Bone parallel to world z axis flicking when scale in edit mode. #38843
6 Participants
Reference: blender/blender#38843
windows 7 pro 64bit,gtx 580
Broken:9c755ef
Add an armature, switch to edit mode ,select and scale the default bone.
Added subscriber: @YonghaiYu
#38838 was marked as duplicate of this issue
Worked:
f1a0278
and 2.70 testbuild:4789793
Added subscriber: @ideasman42
This issues was introduced by
3fe487217d
Added subscriber: @GaiaClary
◀ Merged tasks: #38838.
I won’t say how much I’m tired of this bone edit mode… Will try to fix that, should not be hard to hack it here :/
This issue was referenced by blender/blender-addons-contrib@65c5be9676
65c5be9676
Closed by commit
65c5be9676
.Changed status from 'Resolved' to: 'Open'
Re-opening. This still causes a glitch with roll compared to 2.69.
Simple example:
roll jumps.
Added subscriber: @beetlegiest
I've been looking at this ticket, the jump is related to the viewport when you start a translation. It is kinda inconsistent what the bone does when you rotate it. If you view the bone looking down depending on the viewport it will rotate differently. If your looking up at the bone it behaves differently than if your looking down, and the jump seems to be dependent on where your viewing. The jump seems to be in the code that normalizes the bone position to see if it is z-axis. If you watch the z vector it jumps from 1 to .6 and I'm guessing thats why the jump is roughly 30+ degrees when it jumps. I just wanted to share what I found already before I checked out for evening, so maybe someone could at least not have to spend as much time debugging. If its still issue tomorrow I'll try and chase down the actual positioning issue to code.
Added subscribers: @BassamKurdali, @JoshuaLeung
See D362…
I'd like to propose to distinguish between "horizontal" bones and "vertical" bones" and setup a rule set like this:
Definition:
Horizontal bone: a bone laying in the X-Y plane
Vertical bone: a bone laying in the Y-Z plane
The above rules would allow to have a human rig in T-Pose where legs and spine bones all have local X axes aligned to global X axis, while arm bones all have local Z aligned to global Z and all bones would have consistent bone roll values (mostly around 0). I agree that bones with a 45 degree angle still would be flipping candidates though.
Finally: Since the Bone roll is (as far as i understand it) a rotation angle around the local Y axis of the bone i do not understand why the roll changes between 0 and 90 degrees while i rotate the bone around the global Y axis. Shouldn't (in the current solution) the Bone roll behave the same like when i rotate around the global X axis where it is either 0 or 180 ?
Closing again, this is a "no good solution" case, you just can’t have a good roll correction in all situations.
D362 is worse imho, either we keep current behavior or we revert to 2.69 code. I would keep current one, because at least you will always get the same result if e.g. you rotate 180° at once, or three times 60°. And 2.69 code also produced weird roll jumps in some cases…
I would actually prefer to switch back to 2.69 behavior because there the orientation of the local X/Z axes is much less confusing compared to the current solution where the bone roll value is calculated in a consistent way, but imo still not in a way that is meaningful to the user...
